    Making PCBs this way is very slow, you know?
    IME it is better to use a professional fabricator - http://www.kikipcb.com/
    Unless you are making rather crude and large PCBs it's a tough job for a mill to do a good job. My PCBs have tracks only 0.2mm wide and similar spacing, that is a difficult ask for an affordable mill.
    C_Bubba's Avatar
    Lives in LaGrange, GA USA, United States. Last Activity: 10 Hours Ago Has been a member for 9-10 years. Has a total post count of 78. Received thanks 10 times, giving thanks to others 2 times.
    I use a combination of Eagle to do the design work and the pcb-gcode ulp to generate the necessary gcode files. For the small one off type of thing that I do as a hobbyist, this works fine.
    The ulp can be found either on the Eagle site or there is a yahoo group dedicated to it.
    Art
    AKA Country Bubba
    (Older than Dirt)
    I need for small job. Maybe 4-5 pcs pcb year
    Example for my job.
    http://i01.i.aliimg.com/wsphoto/v0/1...font-b-ECU.jpg
    C_Bubba's Avatar
    It looks like those boards might easily be handled by Eagle Lite (no cost for a hobbist) and the ulp is also no cost.
    Might be a winner setup for you.
    Art
    AKA Country Bubba
    (Older than Dirt)
    So it is free card for eagle lite?, Would be fun to try cnc , but no one has tips on a cnc router with good price and easy to use!
    C_Bubba's Avatar
    I built my router (about 330mm x 330 mm x ~50mm) and control it with an old DOS program called Turbocnc.
    The router was built with and aluminum channel and flat stock. I found some linear rails to use for the X, Y, and Z. Managed to get a spindle (only 70 watts but works for PCB work). used acme lead screws with derlin nuts for zero backlash.
    Works for me.
    Art
    AKA Country Bubba
    (Older than Dirt)
    How many PCB can you buy for the cost of a router?
  1. Flasher circuit using a BD679
    By ozspeedway in forum General Electronics
    Last Post: 12-07-2014, 08:39 AM
  2. AM882 Alarm Circuit
    By Wobblycogs in forum General Electronics
    Last Post: 28-03-2014, 06:06 PM
  3. -10V to 10v circuit
    By vre in forum General Electronics
    Last Post: 15-01-2014, 12:15 AM
  4. E-STOP Circuit - will this cause any problems?
    By birchy in forum General Electronics
    Last Post: 18-12-2012, 04:35 AM
  5. DC motor drive circuit?
    By Tenson in forum General Electronics
    Last Post: 02-02-2012, 10:32 PM
