I need for small job. Maybe 4-5 pcs pcb year
Example for my job.
http://i01.i.aliimg.com/wsphoto/v0/1...font-b-ECU.jpg
18-10-2015 #2
It looks like those boards might easily be handled by Eagle Lite (no cost for a hobbist) and the ulp is also no cost.
Might be a winner setup for you.Art
AKA Country Bubba
(Older than Dirt)
18-10-2015 #3
So it is free card for eagle lite?, Would be fun to try cnc , but no one has tips on a cnc router with good price and easy to use!
18-10-2015 #4
I built my router (about 330mm x 330 mm x ~50mm) and control it with an old DOS program called Turbocnc.
The router was built with and aluminum channel and flat stock. I found some linear rails to use for the X, Y, and Z. Managed to get a spindle (only 70 watts but works for PCB work). used acme lead screws with derlin nuts for zero backlash.
Works for me.Art
AKA Country Bubba
(Older than Dirt)
18-10-2015 #5
How many PCB can you buy for the cost of a router?
18-10-2015 #6
I do it because I CAN and want to do it. Its not a money thing. I do it to prove to myself that I can. A hobby is not all about saving money, sometimes it is proving that you can do it yourself. If it was all about saving money, I would not have any hobbies and simply buy whatever it is. Also, my hobby projects are typically one off types. I have no plans to manufacture a product. So I can go from a board design to finished board ready to populate in less than an hour usually. How quick can you get a turn around on the board (one off) that you want to buy???
Its different strokes for different folks.Art
AKA Country Bubba
(Older than Dirt)
The Following 3 Users Say Thank You to C_Bubba For This Useful Post:
18-10-2015 #7
18-10-2015 #9
Saying thanks wasn't enough for me. It's been a while I haven't read one like that. To me, even if the things I make myself never pay back for what I spent for the machine, it's all about the fun to design it, make it, and see it coming to life. That, is priceless. Sorry if I'm off topic, but I couldn't hold myself from sharing :)
19-10-2015 #10
My question was actually to the OP who doesn't already have a CNC machine and doesn't have the skills yet. If his goal as set out in the first post is to produce a few PCBs, it will be less expensive and return better quality to use the manufacturer I linked to. £30 will land you a handful of PCBs delivered to your door.
On the other hand, if you are doing this as a hobby then a CNC machine will give you a lot of joy and be highly useful! Alfons37 what is your ultimate goal?Last edited by Tenson; 19-10-2015 at 02:59 PM.
Flasher circuit using a BD679
By ozspeedway in forum General ElectronicsReplies: 15Last Post: 12-07-2014, 08:39 AM -
AM882 Alarm Circuit
By Wobblycogs in forum General ElectronicsReplies: 8Last Post: 28-03-2014, 06:06 PM -
-10V to 10v circuit
By vre in forum General ElectronicsReplies: 17Last Post: 15-01-2014, 12:15 AM -
E-STOP Circuit - will this cause any problems?
By birchy in forum General ElectronicsReplies: 34Last Post: 18-12-2012, 04:35 AM -
DC motor drive circuit?
By Tenson in forum General ElectronicsReplies: 4Last Post: 02-02-2012, 10:32 PM
