    Thought I might share my journey of modifying my RF40. I bought this machine from Axminster tools and shipped it to the UAE where I am currently working. The machine had to fit into a 20ft shipping container which was converted into a workshop - so I was limited on the size of machine I could use. It soon became apparent that this mill has many limitations - which I have slowly been whittling away at.
    The backlash on the leadscrews was so large that using the dials on the axes was no good for anything requiring precision. The first modification was to install linear scales (bought from China on ebay).
    It wasn't long after that I decided to fit stepper motors (also bought from China on ebay). I used a kflop CNC controller which helped to reduce the issues with the leadscrew backlash using feedback from the linear scales.
    The first photo shows the mill in this configuration (sorry - I'm rubbish and remembering to take photos).
    The Z axis drove the drill downfeed via the rack and pinion mechanism built into the mill. This was hopeless under CNC control due to the backlash in the mechanism. More of that later....
    In the end I gave up with the ACME leadscrews and poor quality bearing blocks (which contributed to the backlash) and fitted ball screws to X and Y axes (also from China on ebay)
Name:	2015-03-13 17.39.29.jpg
ID:	16316Click image for larger version.
Name:	2015-02-28 16.59.11.jpg
ID:	16317Click image for larger version.
Name:	2015-03-14 17.02.05.jpg
    Now I am dealing with the real issue with the RF 40 mill - the round column. As anyone that owns one of these machines knows - every time you move the head you lose your Zero.
    So here are a few photos of manufacturing a new boxway column for the mill.
Name:	2015-04-25 12.57.40.jpg
ID:	16319Click image for larger version.
Name:	2015-04-17 17.31.08.jpg
ID:	16320Click image for larger version.
Name:	2015-05-01 16.54.04.jpg
ID:	16321Click image for larger version.
    This project is still ongoing - so I'll post updates as it progresses.
    All of the modifications outlined above (other than the clever bits) are made from scrap steel from my day job (we build pressure vessels, steel structures and piping for a living). So whilst it has taken a lot of manhours in machining and design - the cost of getting the machine to the state it is now would be a lot less than buying a CNC mill. The machine is now accurate in X and Y to +/-0.005mm and will hopefully be as good in the Z axis by the time I have finished !
  2. The Following User Says Thank You to BASMOTRONIC For This Useful Post:
  1. RFQ: Modifications to a Chester 16V Mill
    By Tom_Nelson in forum Projects, Jobs & Requests
    Last Post: 09-09-2015, 07:47 PM
  2. Router Modifications to Allow Cutting of Woodworking Joints
    By EddyCurrent in forum Gantry/Router Machines & Building
    Last Post: 10-01-2015, 12:07 PM
  3. FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
    Last Post: 04-08-2013, 10:30 PM
  4. Chinese CNC machine modifications - Discussion
    By craigrobbo in forum Milling Machines, Builds & Conversions
    Last Post: 14-05-2012, 06:51 PM
  5. Homebuilt Plasma Table Modifications
    By Normsthename in forum DIY Plasma Build Logs
    Last Post: 27-07-2010, 12:58 AM
