01-12-2015 #21
Following this, I was left with little choice but to bypass the feed gearbox, by hanging the motor directly off the main lathe input pulley, and put up with the lack of torque.
This enabled me to produce a new motor front
however, despite my best efforts, its clearly not aligned perfectly, as I can feel the stata grind when turning the shaft manually, either that or the actual shaft or casing was bent when it dropped? Disappointing but I learnt alot, managed to brake my lathe, and lightened my wallet to the tune for £65 on ali. Nevermind
so... I bought a "new" motor (£22 off the bay, 2.2kw)
havent yet fitted it, but it is face mounted, and has a long shaft, so I dont think it will be too difficult.
As for the machine, with thanks for the Dean, I got the servos working.
The servos have 10,000 steps per revoloution, as im driving the ballscrews via 2:1 ratio, and they are 5mm pitch, I make that 4000 steps per mm.
My old faithful parrelel port, cant keep up with that kind of resolution so komatias kindly sold me a ethernet smooth stepper.
I mounted the control box to the side of the machine, using rubber mounts, and made a bracket to mount the monitor keyboard and mouse.
and albeit, not yet including home switches, limit switches, a spindle motor or coolant, the machine is moving
listen how quite those servos are compared to the z stepper!Last edited by kingcreaky; 01-12-2015 at 10:47 PM.
bridgeport
By kingcreaky in forum General DiscussionReplies: 5Last Post: 08-07-2015, 08:11 AM -
Bridgeport VMC with Heidenhain control-
By vargai in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 13-01-2015, 02:37 PM -
FOR SALE: bridgeport interact 4
By cutter23 in forum Items For SaleReplies: 2Last Post: 01-07-2014, 12:47 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM -
Bridgeport BOSS cnc drivers
By speedhound in forum Motor Drivers & ControllersReplies: 1Last Post: 09-12-2010, 01:16 PM
