Nice work Washout!
Adaptive clearing certainly looks like the way to go. Jealous as I looked at Fusion 360 the other day then went to download it and realised that was only for 64 bit (which I knew but had forgotten in my excitement). I've only just upgraded to Win7 32bit on a SSD so it will have to wait for the next PC build.
By the way if the only operation on the flipside was the counterbores why didn't you just use the drill press and a counterbore bit? Save cutting the pocket in the wood and setting it all up again.
Anyway, coming together now . . .
02-11-2015 #2
You must have been reading my mind regarding the counterbores, as it was very tempting just to walk over to the drill press, but sometimes I get "stubborn" and do stuff the hard way just to try the technique out...
BTW - doesn't the key for 32Bit Win7 work for 64Bit Win7 also? - its been a while since I installed 32Bit (the CNC PC is the last one in my household), but I'm sure both versions used to get shipped with one key? Mind you I don't think MACH3 runs on 64Bit iirc so if you're using the same PC for both you may not be able to go 64Bit.My CNC Projects: https://www.youtube.com/imadethisoncnc
FOR SALE: CNC3040 with PC & Monitor (Mach3)
By jeboa in forum Items For SaleReplies: 11Last Post: 10-02-2024, 12:21 AM -
First go at Fusion 360 Adaptive Clearing
By Washout in forum Fusion 360Replies: 0Last Post: 15-10-2015, 07:52 PM -
Can I turn a toolpath image preview into a vector?
By itsmillertime in forum VectricReplies: 7Last Post: 01-08-2015, 12:47 PM -
Toolpath not cutting as shown
By Phizell in forum Machine DiscussionReplies: 23Last Post: 02-05-2013, 12:13 PM
