02-11-2015 #9
You must have been reading my mind regarding the counterbores, as it was very tempting just to walk over to the drill press, but sometimes I get "stubborn" and do stuff the hard way just to try the technique out...
BTW - doesn't the key for 32Bit Win7 work for 64Bit Win7 also? - its been a while since I installed 32Bit (the CNC PC is the last one in my household), but I'm sure both versions used to get shipped with one key? Mind you I don't think MACH3 runs on 64Bit iirc so if you're using the same PC for both you may not be able to go 64Bit.My CNC Projects: https://www.youtube.com/imadethisoncnc
FOR SALE: CNC3040 with PC & Monitor (Mach3)
By jeboa in forum Items For SaleReplies: 11Last Post: 10-02-2024, 12:21 AM -
First go at Fusion 360 Adaptive Clearing
By Washout in forum Fusion 360Replies: 0Last Post: 15-10-2015, 07:52 PM -
Can I turn a toolpath image preview into a vector?
By itsmillertime in forum VectricReplies: 7Last Post: 01-08-2015, 12:47 PM -
Toolpath not cutting as shown
By Phizell in forum Machine DiscussionReplies: 23Last Post: 02-05-2013, 12:13 PM
