Thread: Getting tear-out - need advice
17-12-2019 #6
A downcut cutter will give you a clean top edge. I have found that they do not work well alone, however. Because they have a "down" spiral, they do not clear chips at all. In fact, they force the chips to the bottom of the pocket. This can so jam the cutter that it breaks. (Guess how I know). I have found that I get the best results if I do an initial pass about 0.02" (0.5mm) undersize with a conventional (up-cutting) cutter, then make a final pass to finished size with a down-cutting cutter.
Looking for RYE CNC repair/electrician for maintenance & wear & tear
By xcelkitchensuk in forum Rye CNC RoutersReplies: 0Last Post: 14-07-2015, 09:45 AM
