Page 2 of 2 FirstFirst 12
    Hi Guys
    Anyone using this
    http://www.exair.com/en-US/Primary%2...lications.aspx
    Seems a far safer option.
    Mike
    Mike
    This looks rather good. An exceptional potential alternative to a serious problem.
    Certainly for the home workshop maybe worth considering. Not seen the price though...look before a leap!
    I see that some folk tend to use coolants. Oil in water emulsions and maybe think that these are less harmful.
    Please bear in mind that apart from the chemicals and OIL within, there is an extremely powerful anti-bacteria and fungicide which again in mist can be very harmful. Even fully synthetics will have these.
    Don't be thinking you are safe...just don't be breathing it and you will be.
    Olive oil work perfectly for threading, better than specialised oils. I am threading a lot of aluminum and brass. Emulsify it with water , mist it and prepare your salad.
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 2 Days Ago Has a total post count of 1,654. Received thanks 115 times, giving thanks to others 71 times.
    Even if cutting dry you will need to move chips and vacuum isn't even close to air for getting chips out of the way in holes and slots, so why not look at something like Boyan's solution to add a little lube to your air, then you can use a good bathroom extractor to keep the mist from filling the workshop,
    - Nick
    So best to look at fog buster or similar? I built my own but limited success with it.
    Reopening this old thread to share an observation about using ethanol as a cutting fluid for aluminum which may help others avoid problems.
    We reported on a machinist who tried this in a poorly ventilated room.
    We do not recommend this.
    See our paper titled “Neurological effects of chronic occupational exposure to alcohol mists and vapors in a machinist”.
    https://www.tandfonline.com/doi/full...6.2020.1768341
  7. The Following User Says Thank You to Marcia For This Useful Post:
  1. Dry Aluminium Cutting Problem
    By Tenson in forum Tool & Tooling Technology
    Last Post: 29-08-2016, 11:41 PM
  2. Aluminium cutting
    By Bush Flyer in forum Metalwork Discussion
    Last Post: 13-05-2016, 09:57 AM
  3. WANTED: Mist lubrication system
    By badgerman in forum Items Wanted
    Last Post: 21-08-2014, 12:28 AM
  4. RFQ: RFQ: Need some thin aluminium cutting
    By stewpid22 in forum Projects, Jobs & Requests
    Last Post: 21-09-2012, 01:11 PM
  5. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
