26-10-2015 #11
26-10-2015 #12
The problem with ethanol is that the Government tax it to hell and back.
If you cut it with methanol to make it poisonous and pyridine to make you throw up, you can escape the tax.
You could spray it on to a tool tip but I have to wonder why. Are you sure you have the right chemical?
26-10-2015 #13
If you have to use ethanol, then use a good single malt. Avoid Ardbeg as it has too high a phenolic content and could cause a build up on the end of your tool.
Cheers (hic)
Rob
26-10-2015 #14
'Meths' or 'Methylated Spirit' is mostly ethanol with a drop of methanol to make it undrinkable. Surely a lot healthier than pure methanol or isopropyl which I mentioned ealier.
28-08-2016 #15
Ladies and Gentlemen
Please...do take very seriously the health and safety aspect of using any type of misting coolant.
Apart from the said flammability issues, the slightest mist , even unseen can be breathed in unnoticed and once in your lungs, there WILL come a time when consequences will manifest themselves.
Vent/extract any form of mist. DO NOT breath it.
Any form of Oil/Chemical on the skin is not good and wise after the event is too late.
If you are using coolants where there is potential skin contact, follow the instructions, Wear protective gloves or at least a skin wet (if necessary) or dry barrier cream and if using hand cleansers, in the main will de-fat the skin so use a conditioning cream.
Those of you that will be expecting cracking skin when the weather turn cold will know what I mean
50 years in the Oil Industry, I could write a book but if you have any issues... feel free
28-08-2016 #16
Hi Guys
Anyone using this
http://www.exair.com/en-US/Primary%2...lications.aspx
Seems a far safer option.
Mike
28-08-2016 #17
28-08-2016 #18
Mike
This looks rather good. An exceptional potential alternative to a serious problem.
Certainly for the home workshop maybe worth considering. Not seen the price though...look before a leap!
28-08-2016 #19
NO....Ever seen a Wine-o ? The "Urban dictionary" suggests a person who like excess wine...but in my experience, it is a Tramp who drinks Meths to excess to achieve oblivion.... but with all the added after effects! POISON.
28-08-2016 #20
I see that some folk tend to use coolants. Oil in water emulsions and maybe think that these are less harmful.
Please bear in mind that apart from the chemicals and OIL within, there is an extremely powerful anti-bacteria and fungicide which again in mist can be very harmful. Even fully synthetics will have these.
Don't be thinking you are safe...just don't be breathing it and you will be.
Dry Aluminium Cutting Problem
By Tenson in forum Tool & Tooling TechnologyReplies: 22Last Post: 29-08-2016, 11:41 PM -
Aluminium cutting
By Bush Flyer in forum Metalwork DiscussionReplies: 55Last Post: 13-05-2016, 09:57 AM -
WANTED: Mist lubrication system
By badgerman in forum Items WantedReplies: 9Last Post: 21-08-2014, 12:28 AM -
RFQ: RFQ: Need some thin aluminium cutting
By stewpid22 in forum Projects, Jobs & RequestsReplies: 0Last Post: 21-09-2012, 01:11 PM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM
