I think there's a chance your container may collapse, I'd go for something cylindrical, possibly with internal bracing,
- Nick
25-10-2015 #2
Then only problem was I was sort of restricted in terms of height space. 18cm was max really. However, I'm going to raise the total height of the table by another 10cm so with 28cm I should be able to find something more suitable. Thanks for the tip.
EDIT: I could go with this 15 litre bucket perhaps (with internal bracing)Last edited by d4cnc; 25-10-2015 at 09:22 PM.
25-10-2015 #3
I know you have space limitations, but you could get one of those ash filter metal canisters with a clip on lid. I bought one for around a tenner from CPC. ALDI do them every so often. There was a thread about it a couple of years ago - search the forum for 'Ash can filter'. The cyclone I made was not very good and the one on Amazon you point to may be what I should be using.
I am wary of using vacuum cleaners as dust extractors as the motors are not designed for long periods of continuous operation, besides the buggers are noisy.
I am unfortunate in that I am allergic to domestic vacuum cleaners and cannot use them. I also have to keep out of the way when my wife is vacuuming. The condition is getting worse and is extending to most forms of household cleaning tasks.
Cheers,
Rob
25-10-2015 #4
Thanks for the tip.. I'm currently reading it now..
http://www.mycncuk.com/threads/6108-...ust-filter-%29
Is the ash can filter to be used with the dust commander too? Is it for giving another layer of filtering? I'll have a hunt around for some under 28cm tall...
EDIT: Possibly this 14l 23cmx23cmLast edited by d4cnc; 25-10-2015 at 11:07 PM.
26-10-2015 #5
It was this one http://cpc.farnell.com/duratool/d019...in_merch=true& but they are all generic Chinese.
The idea I had was to put a cyclone in the top of the ash can, it didn't really work as the dust did not settle enough and a lot went through to the main vac. I took all the gubbins out of the can i.e. the HEPA filter.
I still have the can and I will probably marry it up with a dust commander. My workshop has a Bosch Collecto vac, which is battered and about 20 years old, but refuses to die, but my tools are so deep in sawdust, it is like a bran tub trying to find anything.
Cheers,
Rob
26-10-2015 #6
Ah yes, if I had more height available that'd work great to have the dust commander on top..
I've found mixed posts on Henrys.. though one post in particular seems to be exactly what I had in mind.. (even hiding them under a table!)
http://www.mycncuk.com/threads/7981-...3045#post63045
That seems perfect for my needs.. and as I'm mostly aluminium, it'd work too for that would you say?
26-10-2015 #7
I have this one:
http://www.tesco.com/direct/earlex-w...r/204-6450.prd
Not sure who sells them now but I got is for around £55 from Tesco.
You can get a combination filter from tool station. It does not have large capacity and can be loud but works very well for the price.https://emvioeng.com
25-10-2015 #8
I've been through a few vacuum cleaners over the years. Started with a cheap (£30) little thing that soon died.
Then bought a bin style one for around £100. But this was very noisy (brushed motor) and whined. Eventually this died as well.Something like this one:
http://www.charnwood.net/shop/produc...ractor-1?cid=8
Been using a Henry for a while now and it has been great. VERY quiet (no whine!), plenty of suction, easy change bag, small and mobile. Runs for ages without getting warm (possibly because they are designed for commercial use?).
Bought mine at a local supermarket, but here is a random link to show you what it looks like this:
http://www.currys.co.uk/gbuk/home-ap...151025215151:s
Would recommend it.
Adding an intermediate collector (dust commander etc) as you mention is also worth thinking about.
25-10-2015 #9
I was just about to post if something like your second link would be more like what I'd need Draper 10923 but the reviews state, as you have, that they're extremely noisy.
So a Henry is the way to go? Do you keep it on your cnc machine for hours at a time? The one you linked is a 580W whereas the noisy one linked is double that. Is that not an issue in reality?
EDIT: Ah there's also a Henry with 2 switchable speeds.. 1200W & 600W. Is that the one you use and recommend?Last edited by d4cnc; 25-10-2015 at 11:38 PM.
28-10-2015 #10
QUOTE[I was just about to post if something like your second link would be more like what I'd need Draper 10923 but the reviews state, as you have, that they're extremely noisy.
EDIT: Ah there's also a Henry with 2 switchable speeds.. 1200W & 600W. Is that the one you use and recommend?]
OK, managed to check the spec of my Henry and it is 580W non-switchable. But suction is not a problem. Be careful of just looking at wattage to determine how well it might work as this is just electrical input - I do know that the motor type is different to the cheap can type, and it certainly is much quieter.
I have run it for extended periods (at least an hour) following the cutter around, and didn't notice heat etc. but now that my dust shoe is finished and working I use a proper extractor. I then use the Henry to generally tidy up. Must post a video / pics on that when I have a moment.
I haven't used the 1200/600 version so can't comment but I'd be fine recommending the 580W version. When I was looking at all this ages ago there was some ruling coming in about maximum power allowed in future vacuum cleaner models (to save energy) so this could be something to do with the 580W version - but please check this before deciding.Last edited by routercnc; 28-10-2015 at 09:47 PM.
DIY Vacuum Fixtures
By Boyan Silyavski in forum Tool & Tooling TechnologyReplies: 32Last Post: 27-09-2016, 01:25 PM -
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
uPVC CNC Corner Cleaner
By StuH in forum Machine DiscussionReplies: 2Last Post: 20-07-2013, 12:09 AM -
broken ultrasonic cleaner?
By graffian in forum General ElectronicsReplies: 3Last Post: 21-11-2012, 01:02 PM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
