Then only problem was I was sort of restricted in terms of height space. 18cm was max really. However, I'm going to raise the total height of the table by another 10cm so with 28cm I should be able to find something more suitable. Thanks for the tip.
EDIT: I could go with this 15 litre bucket perhaps (with internal bracing)Last edited by d4cnc; 25-10-2015 at 09:22 PM.
25-10-2015 #2
I know you have space limitations, but you could get one of those ash filter metal canisters with a clip on lid. I bought one for around a tenner from CPC. ALDI do them every so often. There was a thread about it a couple of years ago - search the forum for 'Ash can filter'. The cyclone I made was not very good and the one on Amazon you point to may be what I should be using.
I am wary of using vacuum cleaners as dust extractors as the motors are not designed for long periods of continuous operation, besides the buggers are noisy.
I am unfortunate in that I am allergic to domestic vacuum cleaners and cannot use them. I also have to keep out of the way when my wife is vacuuming. The condition is getting worse and is extending to most forms of household cleaning tasks.
Cheers,
Rob
25-10-2015 #3
Thanks for the tip.. I'm currently reading it now..
http://www.mycncuk.com/threads/6108-...ust-filter-%29
Is the ash can filter to be used with the dust commander too? Is it for giving another layer of filtering? I'll have a hunt around for some under 28cm tall...
EDIT: Possibly this 14l 23cmx23cmLast edited by d4cnc; 25-10-2015 at 11:07 PM.
26-10-2015 #4
It was this one http://cpc.farnell.com/duratool/d019...in_merch=true& but they are all generic Chinese.
The idea I had was to put a cyclone in the top of the ash can, it didn't really work as the dust did not settle enough and a lot went through to the main vac. I took all the gubbins out of the can i.e. the HEPA filter.
I still have the can and I will probably marry it up with a dust commander. My workshop has a Bosch Collecto vac, which is battered and about 20 years old, but refuses to die, but my tools are so deep in sawdust, it is like a bran tub trying to find anything.
Cheers,
Rob
26-10-2015 #5
Ah yes, if I had more height available that'd work great to have the dust commander on top..
I've found mixed posts on Henrys.. though one post in particular seems to be exactly what I had in mind.. (even hiding them under a table!)
http://www.mycncuk.com/threads/7981-...3045#post63045
That seems perfect for my needs.. and as I'm mostly aluminium, it'd work too for that would you say?
26-10-2015 #6
I have this one:
http://www.tesco.com/direct/earlex-w...r/204-6450.prd
Not sure who sells them now but I got is for around £55 from Tesco.
You can get a combination filter from tool station. It does not have large capacity and can be loud but works very well for the price.https://emvioeng.com
26-10-2015 #7
Awesome. Choices choices choices..
the Earlex seems to have great reviews and also some that say they work great for CNC type work..
And cheaper than the Henry I saw.. although the Henry is smaller which is better for me...
Perhaps I'll toss a coin..!
31-10-2015 #8
I'm using a wet n dry vac from wickes works realy well and was only 40 quid , I 3d printed a dust boot I found on thingiverse it works great, first thing I've made for my 6040
http://www.thingiverse.com/thing:327156
31-10-2018 #9
25-10-2015 #10
I've been through a few vacuum cleaners over the years. Started with a cheap (£30) little thing that soon died.
Then bought a bin style one for around £100. But this was very noisy (brushed motor) and whined. Eventually this died as well.Something like this one:
http://www.charnwood.net/shop/produc...ractor-1?cid=8
Been using a Henry for a while now and it has been great. VERY quiet (no whine!), plenty of suction, easy change bag, small and mobile. Runs for ages without getting warm (possibly because they are designed for commercial use?).
Bought mine at a local supermarket, but here is a random link to show you what it looks like this:
http://www.currys.co.uk/gbuk/home-ap...151025215151:s
Would recommend it.
Adding an intermediate collector (dust commander etc) as you mention is also worth thinking about.
DIY Vacuum Fixtures
By Boyan Silyavski in forum Tool & Tooling TechnologyReplies: 32Last Post: 27-09-2016, 01:25 PM -
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
uPVC CNC Corner Cleaner
By StuH in forum Machine DiscussionReplies: 2Last Post: 20-07-2013, 12:09 AM -
broken ultrasonic cleaner?
By graffian in forum General ElectronicsReplies: 3Last Post: 21-11-2012, 01:02 PM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
