Thanks for the tip.. I'm currently reading it now..
http://www.mycncuk.com/threads/6108-...ust-filter-%29
Is the ash can filter to be used with the dust commander too? Is it for giving another layer of filtering? I'll have a hunt around for some under 28cm tall...
EDIT: Possibly this 14l 23cmx23cmLast edited by d4cnc; 25-10-2015 at 11:07 PM.
26-10-2015 #2
It was this one http://cpc.farnell.com/duratool/d019...in_merch=true& but they are all generic Chinese.
The idea I had was to put a cyclone in the top of the ash can, it didn't really work as the dust did not settle enough and a lot went through to the main vac. I took all the gubbins out of the can i.e. the HEPA filter.
I still have the can and I will probably marry it up with a dust commander. My workshop has a Bosch Collecto vac, which is battered and about 20 years old, but refuses to die, but my tools are so deep in sawdust, it is like a bran tub trying to find anything.
Cheers,
Rob
26-10-2015 #3
Ah yes, if I had more height available that'd work great to have the dust commander on top..
I've found mixed posts on Henrys.. though one post in particular seems to be exactly what I had in mind.. (even hiding them under a table!)
http://www.mycncuk.com/threads/7981-...3045#post63045
That seems perfect for my needs.. and as I'm mostly aluminium, it'd work too for that would you say?
26-10-2015 #4
I have this one:
http://www.tesco.com/direct/earlex-w...r/204-6450.prd
Not sure who sells them now but I got is for around £55 from Tesco.
You can get a combination filter from tool station. It does not have large capacity and can be loud but works very well for the price.https://emvioeng.com
26-10-2015 #5
Awesome. Choices choices choices..
the Earlex seems to have great reviews and also some that say they work great for CNC type work..
And cheaper than the Henry I saw.. although the Henry is smaller which is better for me...
Perhaps I'll toss a coin..!
27-10-2015 #6
I can't seem to find the Earlex anywhere, so think I'll go with the Henry. Not even sold on their own website..
One thought I've had though is I'll probably be using liquid lubricant for cutting aluminium.. is that going to affect the Henry? Or will the dust commander cyclone take care of that and no liquid will get in to the Henry?
27-10-2015 #7
You need a wet & dry vacuum then. There is a Henry type that is industrial.
31-10-2015 #8
I'm using a wet n dry vac from wickes works realy well and was only 40 quid , I 3d printed a dust boot I found on thingiverse it works great, first thing I've made for my 6040
http://www.thingiverse.com/thing:327156
08-11-2016 #9
This one fits for purpose
https://www.averncleaningsupplies.co...vacuum-cleaner
09-11-2016 #10
DIY Vacuum Fixtures
By Boyan Silyavski in forum Tool & Tooling TechnologyReplies: 32Last Post: 27-09-2016, 01:25 PM -
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
uPVC CNC Corner Cleaner
By StuH in forum Machine DiscussionReplies: 2Last Post: 20-07-2013, 12:09 AM -
broken ultrasonic cleaner?
By graffian in forum General ElectronicsReplies: 3Last Post: 21-11-2012, 01:02 PM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
