This ebayer has lots of those pumps at all different ranges of power..
Would you feel the 70W is adequate or would you recommend a bump up to a higher power pump? Is the Lidl one a 300W one? Like this one? Would you recommend that over the pond type?
If I can't get a George vac for a good price then I think I'll go for that Wickes one.. they have stock in my local store..
When you say you use WD40, are you applying it manually? Often? I'm planning to semi enclose the machine with a plastic dust/mess guard.. but applying at the beginning I can do easily enough. Doing some research now and the idea of dry machining aluminium seems to be a workable option for some.. (obviously whether I can make it work in my case is another story, but perhaps it wasn't so outrageous as I thought when I speculated...)Last edited by d4cnc; 28-10-2015 at 05:35 AM.
28-10-2015 #2
I've been using one of those Wickes vacuums for about 3 years now, as a hand-held dust extractor on the router and general shop clean-up machine (including aluminium swarf off the milling machine and all). Gets a fair bit of abuse, sometimes a few hours running continuously, and just gets on with it. The internal filter (I fitted the wet&dry one which is an extra) does get clogged with MDF dust fairly easily but it cleans reasonably well by holding it over the dustbin and tapping. I didn't really expect it to last as long as it has.
28-10-2015 #3
First of all I do not think that these pond pumps will have enough oomph to run a mister. They only produce a couple of psi. I will try it out later today, but I would not recommend them for anything but delivering a gentle stream of air for a long time.
That is the LIDL compressor, but you may find it soon in LIDL at that price and with a warranty. It has a useful accessory kit with it, which includes a blower gun, but I wouldn't run it continually (it has a pressure switch to cut it out when not in use).
Yes I squirt the wd40 from the can by hand.
I notice you are another bugger that can't sleep !
Cheers,
Rob
28-10-2015 #4
I have tested the mister with the pond pump and the airbrush compressor and neither have enough guts to pull the liquid up the feed tube.
Disappointing !
28-10-2015 #5
Ah a fellow night owl indeed. Always been that way.. so I've always worked nights pretty much..
So I'd need to step up the compressor you think? Those previously mentioned won't clear well enough?
How about something like this... Tyre inflator
Or are we fighting a losing battle by thinking tankless?
PS. I can get a George vac for £90 if willing to take it on a 2hour train ride home with me.. However with the good feedback on the Wickes vac, I may go that route now.. Can't work out if the George is worth the extra £50 & nightmare journey...Last edited by d4cnc; 28-10-2015 at 04:38 PM.
28-10-2015 #6
I can't advise you on that compressor. My current workshop compressor is from LIDL and ALDI have just done a better one, but £169 compared with LIDL's £90. These sort of compressors are noisy though. I wouldn't want you to spend your money on something not up to the job. Both LIDL and ALDI Customer Services are pretty good about finding a store that still has stock, though it was a while back. If you are not in a hurry they will be back in stock in a few months.
28-10-2015 #7
Your Lidl one is this one perhaps? My main issue I have with larger compressors is the space.. I'm trying to fit most things under the table I'm going to build for it..
Here's a quick little mock up I did using this air compressor but still having trouble fitting everything.
Wickes doesn't have dimensions on their site.. so not sure on what size it is so have the original Henry in there still..
There is a work bench next to this with space underneath (up to 190mm height) which I'm planning to put the PC under.. and if there was a compressor quite flat then it could also go under there, but they don't appear to come in the form factor that could fit under..Last edited by d4cnc; 28-10-2015 at 05:33 PM.
28-10-2015 #8
What about using the splitter manifold and plumbing a pipe into the oil/coolant container to create positive pressure to force the coolant through the pipe, that may work? if you could give it a try t will save me a few quid as that is what I was planning.
Cheers, Charlie
28-10-2015 #9
The Following User Says Thank You to cropwell For This Useful Post:
DIY Vacuum Fixtures
By Boyan Silyavski in forum Tool & Tooling TechnologyReplies: 32Last Post: 27-09-2016, 01:25 PM -
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
uPVC CNC Corner Cleaner
By StuH in forum Machine DiscussionReplies: 2Last Post: 20-07-2013, 12:09 AM -
broken ultrasonic cleaner?
By graffian in forum General ElectronicsReplies: 3Last Post: 21-11-2012, 01:02 PM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
