  1. #9
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 23 Hours Ago Has a total post count of 807. Received thanks 101 times, giving thanks to others 176 times.
    If you can lever off the bottom bearing you could try something like this.
    http://www.tools-4-you.co.uk/Hand%20Tools/ball_tie.htm
    If the bearing wasn't on the shaft a sharp strike to the back of the chuck should break it(the taper not the chuck)
    Sorry about that missed the bit where you had tried the taper wedge tried to delete the message but couldn't
    You could grip the shaft in the vice just behind the bearing (to prevent it moving) and try the wedge again.
    Regards
    Mike
  1. Replies: 3
    Last Post: 01-11-2014, 09:28 PM
  2. Bearing fit problem
    By paulus.v in forum Linear & Rotary Motion
    Last Post: 09-10-2013, 09:54 AM
  3. Zapp 3-Axis kit - putting it all together
    By birchy in forum Motor Drivers & Controllers
    Last Post: 18-02-2013, 12:05 PM
  4. Making timing pulley - putting theory into action
    By wiatroda in forum Metalwork Project Showcase
    Last Post: 28-11-2011, 02:22 AM
  5. FOR SALE: bearing/belts
    By oadamo in forum Items For Sale
    Last Post: 03-01-2011, 12:43 PM
