    Nema 23 motor with 8mm shaft... but there are many of theese, different types... any that is recomennded for usage with a co2 laser and drivers
    Is it best to use dual shaft motor in Y axis?
    Will this do:
    Nema 23 motor for y axis
    • Step angle: 0.9 deg
    • Step per revolution: 400
    • Phases: 2
    • No. wires: 4
    • Current: 2.1A
    • Holding Torque: 0.9 N.M (127 oz*in)
    • Dual Shaft: 6.35mm in diameter
    • Dual Shaft length: 21mm
    • Inductance: 2.5 mH
    • Phase resistance: 1.8 ohms
    • Detente torque: 400 gcm
    • Rotor Inertia: 280 g-cm2
    • Weight: 0.6KG (1.4lb)
    • Length: 54mm
    The 6040 uses 200 step NEMA17 motors which are really zippy at 12V.
    There are no cutting forces, you really want to keep this as light as possible, especially if you want to scan a cross hatch engraving.
    I see. What about the step angle?
    I see there are 0.9, 1.2 and 1.8 angle.
    Should I go for an nema 17 also for the x axis ?
    regards
    Sorry cross purposes, I am trying to do too much and, apparently, failing miserably
    I am talking about the cheap Chinese laser, you are talking about converting a cheap Chinese router table in to a laser
    Please ignore everything I said
    hehe
    I have ordered the rail kit from mjunit Link here want to build co2 laser cutter/engraver from scratch :) I think that is better than ordering theese systems.
    Regarding the motors and drivers, I am a bit confused... There are a sh*tload of different nema 17 and nema 23 motors.
    They recommend nema23 motors since they have 8mm shaft. And the kit contains 8mm couplings and mounts for nema 23. But I am lost here...so many motors to choose from.
    What do I need to look after regarding motors and drivers?
    I would be gratefull for any tips regarding motor + driver :D
    Just received the parcels today. Well packed.
Name:	Skjermbilde 2015-11-10 kl. 17.41.05.png
ID:	16503Click image for larger version.
Name:	Skjermbilde 2015-11-10 kl. 17.41.14.png
    Here is layout
Name:	Skjermbilde 2015-11-10 kl. 17.43.59.png
    Will build a frame of aluminum extrusions 2020 and 2040.
    More later..
    PS.
    Any tips regarding motors + drivers? ;) It has 57mm mounts.
  1. Thinking about new CAD / CAM
    By Tenson in forum CAD & CAM Software
    Last Post: 13-09-2015, 10:18 PM
  2. Thinking of buying one of these little things
    By Hopey in forum Marketplace Discussion
    Last Post: 19-05-2015, 10:44 PM
  3. Thinking of building a 3d printer.
    By Jester in forum 3D Printing Machines
    Last Post: 24-04-2015, 08:23 PM
  4. Replies: 2
    Last Post: 20-04-2014, 05:19 PM
  5. I'm thinking of bidding on a lathe , what do you think it is worth ?
    By Fivetide in forum Marketplace Discussion
    Last Post: 22-09-2012, 10:50 PM
