    Lives in East Lothian, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Posting this here to see if there's any interest, as I currently have no use for it.
    It's a complete ISO15 spindle, with 8 BT15-ER16 tool holders, and air cylinder for the release.
    I'm open to offers.
    Hello m_c,
    This bit of kit you have here is interesting to me, in as much as I would like to undertand how such would be set up. It is not the tool for me mind. I am looking for an ATC that will take a 12.7mm / 1/2" collet then someone to build me a router. That said, I bet this will make someone a nice bit of kit. If you have anymore info I would like to have a read up on it just out of interest.
    All the best
    Suesi
    I'm guessing it's this one?
    https://www.kickstarter.com/projects...le/description
    If so, what rated speed are the bearings you got in it? I may be interested...
    Not sure if this helps you Jonathan, that kickstarter sure dose look like the right one though:
    "The spindle cartridges and spindle shaft kits are supplied with NTN P42 25deg sealed angular contact bearings and are available with optional ceramic bearings at an additional cost."
    .Me
    Yes, it's the kickstarter spindle, and I only went for the standard bearings, which are supposed to be rated for 15'000rpm.
    If it had been delivered on time, I would of had a use for it, however at the moment it's just an expensive shelf decoration unless I happen to find a cheap donor machine.
    Hi M-C,
    Just been reading your posts and I could be interested in this spindle. Can you give an idea of what your after for it?
    Ali Kat
    fifa's Avatar
    Lives in bristol, United Kingdom. Last Activity: 26-11-2017 Has been a member for 8-9 years. Has a total post count of 31. Received thanks 3 times, giving thanks to others 0 times.
    Hi Suesi
    It fits. You need to change holder type. For ATC you need more anyway...
    Regarding DIY CNC and ATC - has no sense, unless you are very restricted with space, or you have special needs. Easier is to buy used industrial grade machine (and update the controller if needed). It is also more reliable.
    Such I can make one for you. Can be also for steel (mineralcast).
    I have seen a lot of cheap ATC spindles. Common problem: cheap means small diameter bearings ... Whatever you do stiffness suffer. It is cheaper to buy 2 solid fixed spindle motor than one reasonable good ATC (depends also on Max RPM)
    For RPM up to 12.000 : buy an old low profile motor for circular saw with 2" (or at least 50 mm) bearings. With investment of ca 1000 GBP (bearings and machining), - you will get a 15 Nm milling spindle with ATC capability (prices started at 7000 +).
    regards
    martin
    Is there and engineering drawing for this please, id like to see if it might fit my machine :)
    This was sold via eBay a while ago, but for completeness, here's the cartridge dimensions. I'm not even sure if Dale is still selling spindles or not.
    His website is dalecnc.com, but I'd suggest looking at other options.
  10. The Following User Says Thank You to m_c For This Useful Post:
  11. ...being able to turn something 3m long and 1m diameter would be handy though...
  1. FOR SALE: atc tool holders, 3/4in er25 collet holders x10
    By dazza in forum Items For Sale
    Last Post: 11-03-2015, 10:48 AM
  2. WANTED: BT 35 Tool Holders
    By Sparky in forum Items Wanted
    Last Post: 08-01-2015, 06:34 PM
  3. WANTED: QC 30 holders or Erickson or Kennemetal NMTB 30 holders.
    By corkcnc in forum Items Wanted
    Last Post: 14-08-2014, 09:43 PM
  4. BT/ISO15 ATC Spindle Cartridge on Kickstarter
    By m_c in forum Marketplace Discussion
    Last Post: 14-09-2013, 02:15 AM
  5. BT 35 tooling and DA holders
    Last Post: 19-07-2011, 03:22 PM
