20-02-2017 #6
Hi Suesi
It fits. You need to change holder type. For ATC you need more anyway...
Regarding DIY CNC and ATC - has no sense, unless you are very restricted with space, or you have special needs. Easier is to buy used industrial grade machine (and update the controller if needed). It is also more reliable.
Such I can make one for you. Can be also for steel (mineralcast).
I have seen a lot of cheap ATC spindles. Common problem: cheap means small diameter bearings ... Whatever you do stiffness suffer. It is cheaper to buy 2 solid fixed spindle motor than one reasonable good ATC (depends also on Max RPM)
For RPM up to 12.000 : buy an old low profile motor for circular saw with 2" (or at least 50 mm) bearings. With investment of ca 1000 GBP (bearings and machining), - you will get a 15 Nm milling spindle with ATC capability (prices started at 7000 +).
regards
martinLast edited by fifa; 20-02-2017 at 12:24 AM.
FOR SALE: atc tool holders, 3/4in er25 collet holders x10
By dazza in forum Items For SaleReplies: 3Last Post: 11-03-2015, 10:48 AM -
WANTED: BT 35 Tool Holders
By Sparky in forum Items WantedReplies: 2Last Post: 08-01-2015, 06:34 PM -
WANTED: QC 30 holders or Erickson or Kennemetal NMTB 30 holders.
By corkcnc in forum Items WantedReplies: 0Last Post: 14-08-2014, 09:43 PM -
BT/ISO15 ATC Spindle Cartridge on Kickstarter
By m_c in forum Marketplace DiscussionReplies: 12Last Post: 14-09-2013, 02:15 AM -
BT 35 tooling and DA holders
By Kai in forum General DiscussionReplies: 0Last Post: 19-07-2011, 03:22 PM
