31-10-2015 #4
For Cut2D I just drawn the overcuts in CAD as my version of Cut2D doesn't automatically do this operation.
But Cambam has an option to overcut the internal corners to allow something with square corners to fit inside, but you will have gaps on the outside as Neale mentions.
Scroll halfway down:
http://www.cambam.info/doc/plus/WhatsNew.htm
Or if I need dead square corners in wood I just file them square by hand - you could do the same in carbon fibre?
I know this is off topic slightly but on metal you can broach square holes, you can spark erode square holes (or whatever shape you machine the eroder bit to be), and if you have a look at John on NYCCNC you will see machined square holes being made using a special broaching device:
(scroll to 11:30 for the machining operation)
https://www.youtube.com/watch?v=-MidOdzxT7k
Black Cat 3020 CNC not cutting square problem
By Fivetide in forum Chinese MachinesReplies: 10Last Post: 22-05-2015, 03:10 PM -
In profile mode Mach cuts corners off? Shortest distance issue?
By marbles in forum Artsoft Mach (3 & 4)Replies: 16Last Post: 29-04-2015, 12:34 PM -
the mystery of the wonky corners
By kingcreaky in forum Machine DiscussionReplies: 19Last Post: 06-05-2014, 03:58 PM -
Cutting wooden letters and shapes - purchase help for a newbie please!
By kemo_2002 in forum Marketplace DiscussionReplies: 18Last Post: 29-08-2012, 11:40 PM -
NEW MEMBER: At the sharp end
By chancersw in forum New Member IntroductionsReplies: 3Last Post: 18-08-2009, 12:39 AM
