    Hi
    I have purchased a 1.5 kW Chinese spindle and need cable from inverter to spindle.
    It seems from what I have read, a sutable cable to use would be; Alpha Wire 4 Core Screened 14AWG?
    Does any one know where I can obtain aprox 2 meters length of this cable, in the UK? (As I do not wish to purchase a whole drum.
    No you don't need anything that heavy 1.5mm/2 or even 1mm/2 CY cable will work fine. Also while there will be 4 pins on the connector only 3 or them are actually used so you only need 3 core.
    Often poeple use 4 core because it's the same cable they would use for the steppers. Or they want to add there own a Ground for the spindle, personaly I don't find a need.
    I can suggest a supplier that will sell by the meter but they will want more for carriage than the cable so probably not worth it really. You'll be better going to Maplins or local electrical supplier and asking for CY cable.
    http://www.csecables.com/acatalog/CY-Cable-p1.html
    Thank you Dean. I have just ordered some 1mm/2 CY cable on ebay . 3 meters total £10 (yes a lot of money , but I can not find any cheaper and I wont it now).
  5. #4
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by 142victoria View Post
    I hope you ordered 3 or 4 core and not 2 core !!
  6. #5
    Thanks Clive , Sure thing .(Thats is 1mm/squared)
  2. motor and spindle cable size?
    By paulus.v in forum General Electronics
    Last Post: 04-02-2014, 10:18 PM
  3. Adding earth cable to 2.2Kw Chinese Spindle
    By Dwayne Dibbley in forum Generic Chinese Spindles
    Last Post: 13-03-2013, 04:04 PM
  4. VFD Cable and 2.2kw spindle wiring
    By Flamered in forum Spindles & Drive Motors
    Last Post: 24-08-2012, 07:29 PM
  5. WANTED: Spindle holder for 1.5kw Chinese spindle.
    By jcb121 in forum Items Wanted
    Last Post: 14-10-2011, 02:07 PM
