Thread: 1.5 kw Chinese spindle cable
01-11-2015 #2
No you don't need anything that heavy 1.5mm/2 or even 1mm/2 CY cable will work fine. Also while there will be 4 pins on the connector only 3 or them are actually used so you only need 3 core.
Often poeple use 4 core because it's the same cable they would use for the steppers. Or they want to add there own a Ground for the spindle, personaly I don't find a need.
I can suggest a supplier that will sell by the meter but they will want more for carriage than the cable so probably not worth it really. You'll be better going to Maplins or local electrical supplier and asking for CY cable.
http://www.csecables.com/acatalog/CY-Cable-p1.html
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
motor and spindle cable size?
By paulus.v in forum General ElectronicsReplies: 4Last Post: 04-02-2014, 10:18 PM -
Adding earth cable to 2.2Kw Chinese Spindle
By Dwayne Dibbley in forum Generic Chinese SpindlesReplies: 4Last Post: 13-03-2013, 04:04 PM -
VFD Cable and 2.2kw spindle wiring
By Flamered in forum Spindles & Drive MotorsReplies: 7Last Post: 24-08-2012, 07:29 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
