    Ha yeah thats a monster.
    I decided to make it 2000x1900mm I'll just have to get it trailered away if I ever need to move it. 1900 will just squeeze through the garage door lol. And I think i'll probably make it only 500mm Z travel. The raising bed will make up for it I think. One thing I can envision needing todo in the future is deep pockets, where the length of the cutting tool and the width of the spindle would be the limiting factor, maybe make a super thin spindle if it becomes a problem.
    I see what your saying about the accuracy but I may aswell do everything I can to make it better. If I get the poor quality screws thats just another inaccuracy to add on. I can't do anything about those other inaccuracies but I can about this and it wont cost much more so why not?
    Not sure about locking it, maybe once i've got the machine built I can use it to make some locking devices. I've no way to make them especially with any accuracy at the moment. Not sure it will be a big issue to be honest, the weight of the bed will take up the ballnut backlash. I guess the main benefit would be reduced power consumption you'd get from turning off the motors. I could also use double ballnuts which would probably be a much simpler solution, the ballnuts I should be able to get cheap from fred.
    I had a question about the gantry design though, need to get it designed so you lot can see, I've been trying to learn how to use fusion 360,solidworks and sketchup but I just can't get along with any of them. Give me AutoCAD 2000 any day of the week over these, I don't know how they can take a program thats so simple and works so well and thoroughly ruin it.
    Any thoughts on an under slung gantry? I'm just thinking if i'm using 200 or 250mm box section and mounting to the top of the gantry then the Z axis is effectively 200mm + rail / cartridge height before its even descended at all.
    It might be a little tricky to mount the rail, i'd have to jack it up off the bed I suppose. The gantry could be epoxy leveled upside down.
    Quote Originally Posted by Rufe0 View Post
    It crossed my mind too as you are right there is much less Z offset doing it that way. I did sketch something up but the problems I encountered were:
    > Side rails cannot easily be supported back down to the bed as the gantry and rails are in the way. The supports down to the bed would have to be outboard of the rail which puts in a bit of an offset.
    > Rails and ballscrews are exposed to swarf and potentially clamp collisions which is not ideal.
    I looked at the commercial machines and they were on top so I went that way. If it helps the box section for the gantry could probably be much smaller as with 2 of them you significant reduce the twisting. I would expect 2off 50x50 sections to be twice as good as 1off 50x50 for bending in X and Z, but importantly, significantly better than x2 for twisting. This is where the advantage is with 2 beams on the gantry.
    I also looked at rails on the inside faces, which is what Jonathan did on the 'sufficiently stiff machine', which is a bit more out of the way and has less Z offset. Downside is it spaces the beams out a bit further for loss of gantry travel. Not a deal breaker if you can make the machine longer.
    I think I understand you. I would mount it normally and reduce the travel by the frame width on each side.
    Just a little update, been a bit busy at the moment unfortunately however it maybe fortunate I didn't get too far as there are a lot of changes afoot, potentially moving house, as a result I can't guarantee I will have a nice big garage to put my machine in anymore. Possibly have to set it up in a bedroom, so it's going to have to be a lot smaller. I'm thinking 500x1000 working area is about the smallest I would want togo. Needs to disassemble into small parts. No pieces larger than about 1900x70 in order to fit through doors, and ideally all parts would be as small and light as possible so it's easy to carry them upstairs etc.
    Still need decent Z travel, tall items, primarily for steel/aluminium.
    Probably my best bet would be a bridgeport mill but that would be a bit of a challenge to carry upstairs...
    it would also be a challenge for the floor boards.
    Indeed indeed, so just brainstorming what my options are now. Thinking the height adjustment on the bed is abit of a hassle I could do without. But I still want to be able to work on tall items. So that leaves me with a very tall machine, would have to use waste boards or something to space the work up, maybe a hassle maybe not. Something like this.
    I'm wondering if there would be a better way though. I had an idea... it's basically a fixed gantry except the bed is fixed and the gantry moves(not shown but bed would sit on supports at both ends). I think it would look really cool, like some sort of scanner out of a sci-fi movie. Would offer better access aswell and I think I could make it significantly lighter. * not a proper drawing just an artists interpretation * shown with spindle hanging out the front for ease of drawing, obviously it would be a dual gantry with centralized spindle.
ID:	17149Click image for larger version.
ID:	17150Click image for larger version.
    I think both would suffer from strength issues, especially as there is no diagonal support to stop skewing.
    Any thoughts?
  1. Nitrile O-ring belt drive - suggested stretch percentage..?
    By Wal in forum Linear & Rotary Motion
    Last Post: 13-05-2014, 11:49 PM
  2. Domestic ring main wiring
    By mekanik in forum General Electronics
    Last Post: 15-10-2013, 05:50 PM
  3. Simple O-ring calculator.
    By jcb121 in forum General Computing
    Last Post: 26-07-2013, 09:00 PM
  4. how to measure a ring for cnc.
    By crimsonred in forum Probing, Digitizing & Scaning
    Last Post: 27-09-2010, 02:47 PM
  5. Scrool jaw ring for hydraulic soft jaws.
    By Pmac in forum Tool & Tooling Technology
    Last Post: 28-01-2010, 07:55 PM
