    Quote Originally Posted by Hemsworthlad View Post
    small lathe required:naughty:. . . . much easier. . . . . and cheaper
    Yes, that's beginning to dawn on me. You'll gather that I'm the kind of guy that'll try & knock something he needs ala scrapheap challenge, but I think a lathe is beyond my ability! I'm now scratching around wondering what I can sell to placate my wife if I do utter the unmentionable under my breath "I think I need a lathe honey" ...it's likely to be a kidney. It'll then likely cost me double as she goes out to spend the equivalent (shoes, clothes, food - other unecessary stuff )
    Ok, I said they'd be bad - it's about the only commitment I can meet!
    Hopefully, this will help visualize what I'm aiming for....
    & here's a recent coil prototype...
    It quickly became apparent, I need a better bobbin (those are sewing machine Bobbins bought from Boyes, Whitby @15p each! The diameter is (ar too wide & the centre hole is just over 6mm ...but then I'm into the domain of specialist bobbins (min order 1000s!). Then I thought, actually because space is so tight (the pickup from top to bottom must come in at less than 9mm in height - see cross section sketch immediately above), then I really ought to dispense with the bobbine completely - this is when my probelms started ultimately ending up here throwing myself at the mercy of the forum!
    Cool - that rig actually looks very good (see what you mean about the 9mm diameter - that'd be fine)
    When you mount the larger holder in a chuck, how does it turn overall? In my simplistic head, I just can't imagine that it'd turn 'true' ....as it looks like the opposite part would potentially cause wobble, (ie if it was out of alignment slightly?)
    Like I say, I could be wrong!
    re measuring those magnets I have...I only own one of those ubiquitous simple digital micrometers (allegedly measuring to 0.01mm accuracy)...it's not the best thing in the world (that said, in the main it suits my simple needs), but they all seem to be coming in at 4.96 - 4.99mm (that variance is more likey to be the inconsistent pressure I'm applying on the micrometer thumbwheel!)...I doubt any would come in over 5mm (on the basis it's cheaper for them to make smaller than larger!) ...& I reckon this simple coil making rig could withstand error of up to .2mm 9ie that's just 0.1mm slack either side of the magnet)
    For once on a forum I'm chuffed to be wrong - Dean that's brilliant.
    If you say the runout wasn't bad & can be (essentially) adjusted away, then that's good enough for me.
    I'll drop you a PM.
    How dose that pick up work? if I may ask. coil winding is next on the list of machines to build. after mill, router, raduis machine and inlay cutter....
    Are each of the coils feed back to amp/processor individualy or are they conected in series for better string balance?
    Sorry to interupt the thead..
    No probs...I've been scant with the details because after all, this is more of a mechanical-centric forum than an electronics forum. The small coils I intend winding aren't actually pickups (I used the term as it was simpler!).
    These coils will actually be sustainer coils. The intention being to keep the guitar strings sustaining as long as the player wants them to. It does this by tapping off the guitar's standard pickup output signal, amplifying it & feeding the signal into these coils...this creates a varying magnetic field...& the guitar strings are ferrous so react to the mahgnetic field.
    the coil is the easy bit...the tricky/creative bit is coming up with a good circuit to drive the coils!
    re the pickup winder...it really is a heath robinson, but essentially it's a main motor, with an encoder disk mounted on iT (a CD label containing a lot of black/white stripes). I created an electronic circuit to synch the main motor with a stepper motor (buy counting the black stripes). It's via the shaft of the 'synchronized' stepper that the enamelled copper wire feeds onto the coil core.
    Because there is so little room to fit my sustainer device (I don't want to route the guitar body), I reckonedthat the only way forward for these coils was to go bobbinless (coils/pickups are normally have a bobbin, upon which the copper wire is fed onto...but the bobbin itself takes space). That's when I had to throw open my plight to this forum...Dean kindly offered to get involved & help out.
    Sounds good, at last a fellow guitarist.......
    Maybe Lee will open a musical instument section so we dont bore the rest.....Building guitars and related parts is is main reason for getting in to cnc.
    Not able to help yet tho as not properly setup.
    So is this basiclly causing the strings to vibrate like feedback?
    BTW always found that a Marshall on full tilt driving a 4X12 is good for sustain.....:dance:
  1. RFQ: Require small Stainless steel buckles machining- can you help please ?
    By Gasgasbones in forum Projects, Jobs & Requests
    Last Post: 15-05-2013, 06:47 AM
  2. Replies: 25
    Last Post: 03-05-2013, 09:31 AM
  3. RFQ: Very simple small part
    By Shinobiwan in forum Projects, Jobs & Requests
    Last Post: 11-01-2013, 01:02 AM
  4. BUILD LOG: small mill for machining steel. Max spend £500 including computer
    By Andrew Wilding in forum DIY Mill Build Logs
    Last Post: 20-07-2012, 03:46 PM
  5. RFQ: Request: 200 units of a small part
    By craynerd in forum Projects, Jobs & Requests
    Last Post: 13-02-2012, 10:25 AM
