23-06-2009 #18
Yes, I thought the same when i started out on this journey, but you do need a magnet (& believe me I've tried just about every permutation).
You can think of the magnet along the lines of DC biasing in electronics terms (best comparison I can make). The guitar strings aren't 'magnets' ...just ferrous material, so the sustainer coil can only pull on them (& release)....that is, the sustainer can't "push" the string away from the coil. By having a permanent magnet, you can then have a slight quiescent pull on the string & then when the AC guitar (drive) signal is added into the mix, you're effectively getting a pseudo pull/push effect (on one half of the AC signal the permanent magnet's quiescent 'grip' on the string is relenquished which is like a pseudo-push...& then the other half of the AC signal the permanent magnet is given a boost, forcing it to pull stronger than in its quiescent state) ...it's difficult to explain in the written word, but yes, you really do need a magnet.
The other option would be to apply a DC biasing current through the coils (ie dispense with the permanent magnet - just a pure solenoid) .....the problem with this method is it'd draw too much current....& power is scarce on a guitar (such guitar circuits normally being driven by 9V PP3s, which are only 500mAH at best)
RFQ: Require small Stainless steel buckles machining- can you help please ?
By Gasgasbones in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-05-2013, 06:47 AM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
RFQ: Very simple small part
By Shinobiwan in forum Projects, Jobs & RequestsReplies: 5Last Post: 11-01-2013, 01:02 AM -
BUILD LOG: small mill for machining steel. Max spend £500 including computer
By Andrew Wilding in forum DIY Mill Build LogsReplies: 44Last Post: 20-07-2012, 03:46 PM -
RFQ: Request: 200 units of a small part
By craynerd in forum Projects, Jobs & RequestsReplies: 1Last Post: 13-02-2012, 10:25 AM
