Do you mean alter the movement amount on the axis in motor tuning to trick it?
to let you know how I start up, I move the axis to lock it in the nearest square face of the table in relation to the spindle then reverse it a bit so it's locked then zero the DRO, so now I mdi g0g90a-91. Then table move and next line is a-90. Which leaves readout in right position but not quite locked the table so I need to move to a-89. And it locks and ok but the readout displays 89.62 or another number which makes a program impossible as I don't know how much the next move needs to compensate for the clamp amount,
should I consider changing the axis motor for a servo but it still needs to clamp before machining and I don't want to be involved with a compressor for a brake........ I dunno,
