    Hi Guy's I need some Help Please?
    I'm having a problem with my Z Axis motor tuning . The settings are listed below. It goes in both directions when I use either of the Z+ or Z- tabs. Have any Ideas on what I'm doing wrong?
    The wiring has been checked and double checked. I'm running the jog rate at 45% and it keeps going in one direction and then reverses the direction. If I run it at 100% it does nothing.
    I listed the settings below
    I'm using M542 drivers.
    Motors
    * Manufacturer Part Number: 23HS45-4204S
    * Motor Type: Bipolar Stepper
    * Step Angle: 1.8 deg.
    * Holding Torque: 3.0Nm(425oz.in)
    * Rated Current/phase: 4.2A
    * Phase Resistance: 0.9ohms
    * Inductance: 3.8mH+/-20%(1KHz)
    BOB http://www.ebay.com/itm/Upgrade-Usb-...item2a4eceaf9b
ID:	16419   Click image for larger version.
    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    You don't say what the voltage of the power supply is that feeds the drives?
    Sorry about that. They are 36Volt
  5. #4
    It could be your Keyboard.!! . . . .Try another. I've had this type of thing happen before and it's been the keyboard related.
    If that doesn't work and your 100% sure your wiring is ok then Re-install Mach3. Also if this is a Dodgy copy of Mach3 that came with the BOB then dump it and download the latest Lockdown version from Artsoft site.
  7. #5
    So I was using a Logitech wireless keyboard and just switched it to a direct USB plug in keyboard and it works fine.
    Thanks for the help Guys.
    Mike
  1. Redsail laser engraver x axis problem
    By sthdklen in forum Laser Machines & Building
    Last Post: 21-03-2015, 03:44 PM
  2. Chinese 6040 from uk eBay seller x axis problem
    By CommanderKenyon in forum Gantry/Router Machines & Building
    Last Post: 20-02-2015, 02:13 AM
  3. Problem with Mach 3 converted lathe x axis Boxford TCL 160
    By FarrerDesign in forum Boxford Lathes
    Last Post: 07-08-2013, 09:37 PM
  4. Replies: 9
    Last Post: 08-06-2012, 12:12 PM
  5. z axis problem on rye ma 1500 with a bosch cc100
    By rickybabe in forum Rye CNC Routers
    Last Post: 28-04-2010, 09:04 AM
