07-11-2015 #2
Wouldn't get anything before having the machine. was just browsing the web looking at AC servos out of curiosity to try and ascertain a rough price.
07-11-2015 #3
Price's vary wildly on quality and size. To give some idea I've just bought 3 x 1.8Kw AC servo motors and drives complete with Cables delivered from China in 5days for the same price has just 1 x Motor/drive set of better brand name. The better brand I'm talking about is still considered relatively low/mid end compared to the bigger boys who's prcies can get eye watering.
Yes the Chinese drives won't match in quality and probably accuracy compared to the big boys but they will more than match anythign I'm going to challenge them to do.
They have all the same Spec regards Encoder counts and I/O etc the better brand offers and so far they look like they are goung to be perfect for my needs.
Time is a good tester but I'm very experienced at testing things and you get a feel for when some things right and when they are just a little too cheaply made.!! . . . These feel dead right and I'm getting very good vibes from them ( Well actually I'm getting No vibes because they are super smooth. . Lol)
Watch this space because I will shout up if the vibes turn into Shakes.!!Last edited by JAZZCNC; 07-11-2015 at 02:05 AM.
07-11-2015 #4
Sinusoidal Signals can be easily converted into TTL RS-422. There are some Chips from IC-haus that make this without big effort. And the price is ridiculously low compared with a HH Exe.
Jazz, is it possible to add linear scales to a IP/M or S control. I have now the "little" Boxford machine and want to convert it later to a servo control, I already have the Motors from Yaskawa and 2 drives for it but they want analog +/-10V. Now I need 3 additional drives for X,Y,Z and another one for B. If I see it right, I have 2 additional analog outputs which can have +/- 10V.
One for an additional 5th axis and one for the spindlemotor which I will change for a much stronger one.
But it were better, if I can add a linear or rotational scale to any axe.
I know the IP/A can make this, but this part is too expensive for me. With all features I want have, it costs more than 1000€.
07-11-2015 #5
No Only the IP-A can have Feed back. You can get a Encoder module for the IP-S for Spindle to allow threading etc.
The IP-S and IP-A are almost the same price so if you can use Analog -/+10v then I'd go that route.
Or look at the Klop and Kanalog route which seem a nice enough setup, thou again not cheap by the time you have expanded it. Will probably be about same money.
Pokeys 57cnc is worth a look and will support high speed encoders. It also has one of the best Mach4 plug-ins out there.!
08-11-2015 #6
I have downloaded the additional manual for the Enc Box. There are 3 Encoder inputs and this part should run with the IP/M Box as well. What can I do with the third Encoder? Or better, is it possible, to connect 2 enc boxes to a IP/M? Than I had 6 encoder inputs 1 for the spindle and 5 for all the axes.
08-11-2015 #7
16-01-2016 #8
Assuming you are talking Heidenhain equipped Bridgeports I think all the controllers from the TNC150 forwards had the capability to add a forth axis. What you may not have is the relevant Bosch servo drive card to drive the 4th axis servo.
I have a Beaver Partsmaster with a Heidenhain TNC 355 controller. I've added a 4th axis to this machine by using a Bosch servo card from a Bridgeport Interact. It works well - I've even recently got the FeatureCAM post processor to let me engrave text on the outside of a cylinder with it :)
I've a build thread on another forum, but I'll have to check with the mods if it's ok to link to it, as I know some forums get a bit shirty about that :)
The Following User Says Thank You to AndrewMawson For This Useful Post:
bridgeport
By kingcreaky in forum General DiscussionReplies: 5Last Post: 08-07-2015, 08:11 AM -
FOR SALE: bridgeport interact 4
By cutter23 in forum Items For SaleReplies: 2Last Post: 01-07-2014, 12:47 PM -
WANTED: 3 axis cnc wanted bridgeport size
By franky in forum Items WantedReplies: 1Last Post: 31-05-2014, 08:57 AM -
Bridgeport series 1 MDI / CNC tooling
By drumsticksplinter in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 08-03-2013, 04:47 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
