I have downloaded the additional manual for the Enc Box. There are 3 Encoder inputs and this part should run with the IP/M Box as well. What can I do with the third Encoder? Or better, is it possible, to connect 2 enc boxes to a IP/M? Than I had 6 encoder inputs 1 for the spindle and 5 for all the axes.
08-11-2015 #2
09-11-2015 #3
I thought, you have already tested, if the enc box is compatible.
At the moment, I'll better try to get the machine running with a Mesa 7i76e that I have already here. That board have all in it what I can do with IP/M + enc + mpg + additional IO.
It have as standard 5 S/D, 1 analog out, 1Encoder in, 32 DI, 16DO and from the DI, I can use 2 ports for a Mpg and another 2ports for analog in for feed or speed rheostat. Additionally I can add 2 other boards with similiar capabilities and to all this boards each a easier Board with additional IOs
But for a further Project, it seems good to use a board, that don't have more in it, than what is needed.
Mach3 as well seems a lot easier than Lcnc but is payware.
10-11-2015 #4
16-01-2016 #5
Assuming you are talking Heidenhain equipped Bridgeports I think all the controllers from the TNC150 forwards had the capability to add a forth axis. What you may not have is the relevant Bosch servo drive card to drive the 4th axis servo.
I have a Beaver Partsmaster with a Heidenhain TNC 355 controller. I've added a 4th axis to this machine by using a Bosch servo card from a Bridgeport Interact. It works well - I've even recently got the FeatureCAM post processor to let me engrave text on the outside of a cylinder with it :)
I've a build thread on another forum, but I'll have to check with the mods if it's ok to link to it, as I know some forums get a bit shirty about that :)
The Following User Says Thank You to AndrewMawson For This Useful Post:
bridgeport
By kingcreaky in forum General DiscussionReplies: 5Last Post: 08-07-2015, 08:11 AM -
FOR SALE: bridgeport interact 4
By cutter23 in forum Items For SaleReplies: 2Last Post: 01-07-2014, 12:47 PM -
WANTED: 3 axis cnc wanted bridgeport size
By franky in forum Items WantedReplies: 1Last Post: 31-05-2014, 08:57 AM -
Bridgeport series 1 MDI / CNC tooling
By drumsticksplinter in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 08-03-2013, 04:47 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
