    Thanks for the advice everyone. Really appreciated.
    Yes I agree, it's almost like a necessary evil to get me started on my cnc journey.. don't run before I can walk I guess..
    Something I've always wondered actually.. when people use a cnc to make a better cnc, which bits are they making? Because presumably the existing cnc isn't strong enough to cut the material that the better machine will be made out of.. ? Or am I too fixated on steel being the material of the machine, and great machines can be made from aluminium..?
    Having said that.. CommanderKenyon brings up a tempting point.. would it be viable to buy say some extrusions, and spindle mount / brackets / bearings.. all off the shelf and build essentially the 6040? Or are there some bits that just have to be custom / precision drilled that wouldn't make it viable for someone without a cnc already.
    (PS. CommanderKenyon, I noticed on another thread, your CNC took an age to arrive too.. Which seller did you buy from? How long did it take? And was the seller as unhelpful with tracking numbers as mine? ie. a tracking number that shows up nothing on DHL's website)
    Quick reply ..
    my my cnc came from ebay seller that said he was in Portsmouth but was not o was pondering over a 6040 for ages and my partner thought she would surprise me . Did she .. Bless her cotton socks .
    wheni say extrusion I don't don't mean a ox type route , these designs although maybe great for 3d printers and laser cutters , are not great for much past light wood , but the 6040 would be better with a structure make of thicker Ali plate 20mm + for ends with maxhined out holes for bearings for 2 x 1605 ballscrew sand 20mm rails and hiwin carriages and 80x40 extrusions for longer lengths , this would be of the starting point for a 6040 machine , I am planning on stripping mine down over weekend if I get chance I will take some pics of its construction but it's a joke without washers the bolt heads would almost pull through the holes for the most part
    im very new to this also and am not professing to know anything realy , my dad was a sheet metal worker and machinest for years , I'm not too bad but have very little machining anything other than few basic tasks I've needed over the years , I'll try and add more to this over weekend. Late just now and getting kicked by missus lol
    Up early...
    Jazz is definitely right, if you go for a Chinese 6040 make sure its a good one!
    I bought a 6040z a year ago 1.5Kw water cooled spindle and the black box controller, I knew that I just wanted to carve Oak etc (no Metals). Following advice on here I immediately changed all of the wiring and added a UC100 USB interface to get as far away from the parallel port as I could for minimum money! I also changed the BOB for a cheap one off eBay (to allow control over the spindle speed and turning on and off) I had a random problem for a while where it would look like one of the axis was losing position! Fortunately I was advised on this forum to adjust the driver current and bingo the machine works really well!
    Part time I have knocked £6k worth of signage business through it in just under 12 months - so I am a happy bunny!
    Would I change anything, Yes if I had the time and space I might build a more custom machine that was faster and enabled me to carve tall projects at the end of the bed, but apart from that it does what it says on the tin.
    Earle
  1. On going chinese 6040 problems
    By amxen in forum Chinese Machines
    Last Post: 03-06-2020, 08:46 AM
  2. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  3. Chinese 6040 from uk eBay seller x axis problem
    By CommanderKenyon in forum Gantry/Router Machines & Building
    Last Post: 20-02-2015, 02:13 AM
  4. Please to identify orange 6040 chinese laser engraver to get it working again!
    By itsmillertime in forum Laser Machines & Building
    Last Post: 26-01-2015, 08:54 PM
  5. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
