Ok so lets get a bit more detail.?
#1 Do you want to make one hole then move away and screw one screw down. Then cycle start move to next hole and repeat.?
#2 Do you want to make all the holes then move out the way and wait for screwing down then carry on with cutting rest of the job.? Has in 2 operations with in one G-code file.?
One is much easier than the other.! Both are relatively easy with Cam software but ones is harder than the other if hand coding but still not challenging coding so to speak if your G-code savy.
Also do you want holes larger than the 2mm bit.? If not then just use a simple peck drilling cycle with small pecks.
If #2 with same size hole then it's simple enough has the G83 peck drill cycle is classed has one operation even thou many holes in different locations.
After the Peck cycle ends you send the machine to the loaction out the way then Issue a M6 tool change. This will wait for tool change and just don't change the tool and push cycle start when finished screwing down.Last edited by JAZZCNC; 05-11-2015 at 11:56 PM.
Anyone got some 2.5D G-code please ?
By dudz in forum Programmers CornerReplies: 5Last Post: 22-06-2013, 11:21 PM -
Cambium Code Web Tools – Parametric G-code Generation
By CambiumMachines in forum Manufacturer NewsReplies: 0Last Post: 09-01-2013, 04:56 AM -
Cnc Code Maker - 2D CAD/CAM
By CncCodeMaker in forum Programmers CornerReplies: 11Last Post: 18-04-2010, 09:31 PM -
G Code help
By moose007 in forum Programmers CornerReplies: 4Last Post: 22-05-2009, 11:39 AM
