09-11-2015 #1
whats the difference between blind hole depth and tapped thread depth? i have 2 plates that i want to bolt together which are 20mm thick so im using m10 cap screws and in solidworks im using the hole wizard and im using the straight tapped option. how do i work out this?
cheers
Ash
10-11-2015 #2
In my CAD programme (not solidworks) the blind hole is used to set the depth of the pilot hole, then the thread depth is usually set less than that so I don't need to tap right to the bottom. Basically the hole is over drilled in depth e.g hole is 15mm, thread to 10mm.
Also I have to do the counterbore and clearance hole in the top plate as a separate CAD operation to the threaded hole in the other plate. Are you trying to do all holes in one go in CAD? Not sure how solidworks offers this in the hole wizard but it could only apply to each part in turn, so 2 separate operations ?
10-11-2015 #3
WANTED: Engraving Machine to engrave around 0.3mm depth, DXF files on aluminium, anyone?
By stuboy in forum Items WantedReplies: 0Last Post: 05-12-2013, 07:28 PM -
Trigonometry help please, plunge depth for a v cutter!
By cncJim in forum Tool & Tooling TechnologyReplies: 13Last Post: 06-11-2013, 03:41 PM -
Blind people doing machining - The Lighthouse for the Blind
By Tenson in forum Machine DiscussionReplies: 1Last Post: 29-07-2012, 08:43 PM -
Z axis not cutting to required depth
By dinasblu in forum Machine DiscussionReplies: 10Last Post: 02-07-2012, 05:38 PM -
End mill depth 'stop' rings
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 10Last Post: 24-02-2010, 02:03 AM
