Thread: Cad / freehand ?
25-11-2015 #113 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle..... CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
25-11-2015 #12
Draftsight does, its what I use to do drawings of RC planes.
25-11-2015 #13
Good to know there's a freebie option, I use BobCAD-CAM V25 for 2.5D, 3D & 4-Axis stuff so I bought the art package with a view to engraving work, it turned out to be of more use for 2D part replication ;-)
- Nick
27-11-2015 #14
I remember something similar in the 80's, a bloke I know spent a bundle of money on a vinyl cutter and computer[they will never catch on].
I never took much notice of it, I was there when he did a van for a local motorbike shop; he drew a logo free hand with pencil and paper, then he went over it with a thing with a lens with cross hairs. I think he had to press a button at points and it created it on the screen.
27-11-2015 #15
Time, and software has moved on. With the quality of digital imaging now available, and with the advent of packages with a good "Trace" function capable of generating vector outlines from bit-mapped images, the time of "digitising tablets" for accurate generation of technical drawings is well past it's sell-by date.
Starting with a scanned image or photograph I use Photoshop for bit mapped image sizing, manipulation and processing then Illustrator for vinyl cutting vector art generation or Bob-Art for machining jobs.
The only potential problem when photographing parts is distortion of the image caused by short focal length lenses, and/or having the focal plane too close to the object, by using at least a 50mm lens with the focal plane at least 1m away for parts up to 100mm length the results are good. For larger parts hanging on a wall and using a telephoto lens from longer distance would make sense.
- Nick
