16-11-2015 #23
Copper burrs are not that big an issue if it happens, simply use a piece of green scotch pad on the board. If you're mill bit is reasonably sharp, no significant burrs will occur.
I use the mill bits from Crownhill:
http://www.crownhill.co.uk/02097.html
They are excellent bits and will give a lovely 0.2mm route around the tracks, which means SMD tracks are easily accompished. I've found that using them at about 6000 RPM will make them last a bit longer and give a nice clean cut.
SOFTWARE NEEDED TO RUN My CNC 3040T
By owen3371 in forum Machine Control SoftwareReplies: 5Last Post: 22-02-2020, 03:38 AM -
Cnc 3040t
By etNick studio in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 15-11-2014, 10:55 AM -
Chinese 3040T Arrives
By Gregor in forum Workshop & EquipmentReplies: 114Last Post: 11-07-2014, 05:55 PM -
DIY CNC router illuminated control panel
By wiatroda in forum Electronic Project BuildingReplies: 5Last Post: 04-06-2014, 11:19 AM -
servo control vs stepper control
By Peter. in forum Motor Drivers & ControllersReplies: 24Last Post: 17-09-2012, 08:36 AM
