    Quote Originally Posted by Musicmanager View Post
    Ok... An example of a 'real' machine ?? Cost ?
    Err do I detect a slight pissed off tone to your reply.?? . . . This wasn't my intention. I'm also sorry if don't or didn't like what I said about these machines but it's a fact.!! . . . Don't hang the messinger.
    WHoa !! No ! No ! No !
    I don't do pissed off .. ..
    My old Dad taught me not to ask a dog an honest question and then start barking .... .. .( if you'll excuse the parody )
    No, a genuine question .. .. . actually anticipating that the answer to the second question would provide the resolution to the first .. .. .. ie .. I'd like to drive a Rolls Royce but I can't afford to :)
    S
    I like the sound of your Old Dad and No offense taken just some times hard to tell.!! . . . . Plus I have canny knack of unintentionally pissing people Off . . .Lol
    Can't offer you an example of a Real machine to look at, Well Not without pissing you off even more.!! . .So Like "My Old Dad" told me don't look at what you can't afford it only "Pisses You Off".!!
    The honest truth is there isn't really any affordable machines worth looking at this side of 5K unless you build your own. Those off the shelf machines at 4-5K tend to be over priced and under spec'd or designed for the money and not what I'd call even "Half Real" machine.
    For a "Real" machine you need plenty of Wonga if your looking to buy rather than build.!
    Yes, I liked the sound of my old dad, it was his left hand applied to my buttocks at speed I wasn't too keen on !
    I came to the conclusion a while ago that an 'off the shelf' model was more wonga than I could justify .. .. so I've started to build one, based on the Sable machine but with some significant modifications. In order to achieve quality I reckoned on a 'bit at a time' approach and I've built the Y axis using a 30 x 30cm aluminium platen on linear bearings running up and down supported stainless linear rails on a heavy blockboard base. I've measured the horizontal and vertical run out and it's minimal. I need to design, get machined and then assemble the gantry next; it will be rigid fixed to the baseboard but at the moment, I'm thinking about how to maintain the parallel of the X axis.
    Meanwhile, I wanted something to read, mark, learn and inwardly digest the art of Mach3, Lazycam, Autoleveller and produce some PCB's in the process; all whilst having some fun with it !
    Thank you for all your advice, much appreciated .. .. .. you should relax when talking to me, you'll find pissing me off a real challenge !
    Bientot
    S
    Hi Jazz
    Sorry, a question I meant to ask you and forgot .. .
    Milling PCB's .. .. lubrication ? Necessary or not ? If so, what to use ?
    S
    Hi Jazz
    S
    Not my thing really but the little I've done I'd say just bit of Blown Air.!
    Oh don't make it a Challenge please because by all accounts I'm naturally very talented at it.!! . . . Been Likened to a Vicious little Dog on a mission.
    Sounds like you have made good start and have handle on things so why not stick a build thread up and then we can help you along the way with anything your struggling with. We'll also take the Piss has well mind but all done in good spirit and with genuine desire to help.
    Yes, good idea .. .. I built the Y axis a while ago and it's in a box until the New Year or so whilst the budget fund recovers .. .. but when I get it out again I'll post it up .. ..
    Back to the subject of reaction and over reaction, I have the most evil sense of humour which gets me into trouble regularly, so don't think you have a monopoly !
    S
    I've used a Chinese 3020 milling machine for making double sided PCBs for a couple of years now and it works remarkably well. The key is to slow down the machine a little for more accuracy.
    They are more than capable of making very tight PCBs ready for surface mount components.
    I haven't used lubrication on the board, simply the vacuum cleaner removing the dust every now and then.
  1. SOFTWARE NEEDED TO RUN My CNC 3040T
    By owen3371 in forum Machine Control Software
    Last Post: 22-02-2020, 03:38 AM
  2. Cnc 3040t
    By etNick studio in forum Milling Machines, Builds & Conversions
    Last Post: 15-11-2014, 10:55 AM
  3. Chinese 3040T Arrives
    By Gregor in forum Workshop & Equipment
    Last Post: 11-07-2014, 05:55 PM
  4. DIY CNC router illuminated control panel
    By wiatroda in forum Electronic Project Building
    Last Post: 04-06-2014, 11:19 AM
  5. servo control vs stepper control
    By Peter. in forum Motor Drivers & Controllers
    Last Post: 17-09-2012, 08:36 AM
