    Hi all,
    I am in the initial stages of a new build.
    I would like a machine that is capable in wood..... i would also like it to be capable in aluminium.
    It will likely be made with Alumnium extrusions as i dont yet weld.
    The space i have for it is quite confined it is 1700mm by 1000mm with 3 walls bounding. The access is on one of the 1700mm sides.
    I need to maximise my cutting length, 1350mm is probably my minimum.
    For this reason i have been contemplating running a long gantry for ease of loading and unloading the machine.
    I like this idea from a practical "in use" perspective, but it worries me from a stiffness perspective.
    so my question is should i continue and design a beefy long Gantry at 1500-1600mm that will be easier to use once built or should i abandon that idea in favour of the narrower (Lighter) gantry and put up with it being a bit more awkward in use?
    thanks in advance for anyone input
  1. NEW MEMBER: Hello form Create space London
    By KevinK in forum New Member Introductions
    Last Post: 13-09-2015, 02:30 PM
  2. BUILD LOG: Reducing the space in my garage.
    By Rich in forum DIY Router Build Logs
    Last Post: 08-04-2015, 11:23 PM
  3. Making decisions about my first CNC
    By TBJ in forum Gantry/Router Machines & Building
    Last Post: 08-01-2015, 09:21 PM
  4. BUILD LOG: Need some final decisions before start building…
    By msacnc in forum DIY Router Build Logs
    Last Post: 22-09-2014, 11:22 PM
  5. Some initial questions....
    By andy586 in forum Gantry/Router Machines & Building
    Last Post: 27-01-2013, 03:00 PM
