Thread: Anyone using CNCdrive products?
22-11-2015 #9
Yes given the fact of not knowing the spec's etc then it would make sense given the prices. Not sure if you saw my Mill post where I recently bought some of these Cheap chinese Servos if not it's here take a look. https://www.youtube.com/watch?v=tW8knRAOr7s
So far just on the bench I'm very happy with them considering the price but time will tell when on machine.
Reading the Drives data they are more than capable of handling 2500ppr encoders so can't see why not. But to be honest I'm not a fan of those plastic encoders they use(if used on there AC motors.?) and by the time you have bought decent encoders then the motors and drives you'll be at more money than the Chinese setup's delivered. For instance £250 will get you 200v/400W servo drive and motor with Encoder cables deliverd to Uk.!!
Honest answer is I don't know to what or if an advantage.!! . . . I would imagine they make for a stronger motor because the higher voltage will allow more push so to speak and the obvious advantage of not needing separate voltage source. But honestly I don't care provided they work and are easy to fit which they clearly do and are.!
Not sure what your meaning here because if you have Step/Dir drives fitted already then surely your Controller must be Step/Dir output.?
Most Modern Servo's allow Both Step/Dir and Analog inputs but the controller must support them and provide +/-10v output that servos input use.!Last edited by JAZZCNC; 22-11-2015 at 12:40 PM.
CNCdrive.com Cheap Servo drives
By BillTodd in forum Marketplace DiscussionReplies: 2Last Post: 13-06-2017, 11:38 AM -
Advice requested for these products and any suggestions; Links below
By mordy in forum Motor Drivers & ControllersReplies: 26Last Post: 14-06-2015, 01:49 PM -
Corian and similar products
By Fivetide in forum General DiscussionReplies: 8Last Post: 20-10-2012, 03:36 PM
