17-11-2015 #3
Also it just occurred to me that you should also check the squareness of your Y axis to the X axis, as if they are not square this can also lead to stalling steppers, and as you said you have been moving the screws by hand then this is a good possibility to check.
An easy way to do this is to very slowly jog your Gantry to its end stops on the X and they should both touch at the same time on either side, if one side has touched and there is a gap on the other side then turn your steppers off and square it up by turning the screw manually, obviously this will only be accurate to a certain degree but worth a check to start.
FOR SALE: Boxford A3 HSRI 3D High Speed Router
By Bartell in forum Items For SaleReplies: 6Last Post: 18-06-2021, 09:03 PM -
Redsail laser engraver x axis problem
By sthdklen in forum Laser Machines & BuildingReplies: 4Last Post: 21-03-2015, 03:44 PM -
NEW MEMBER: Training & Buying CNC router/engraver
By etched-in in forum New Member IntroductionsReplies: 6Last Post: 01-02-2015, 07:15 PM -
High speed router for aluminium tooling 3d profiling.
By gavztheouch in forum Spindles & Drive MotorsReplies: 7Last Post: 07-02-2014, 02:30 PM -
eBay: 1500 x 1000 router any use ?
By EddyCurrent in forum Items On eBay UKReplies: 3Last Post: 24-12-2013, 12:18 PM
