17-11-2015 #4
the strange noise is due to the fact that your stepper motors are stalling.
The stalling can occur if your powersupply or drivers are not supplying enough current to the motors or if you have set your accelerations and rapid speed too high. Not sure what software you are using so best look through your settings yourself.
Trapezoidal screws can be backdriven, as howser says, if their pitch is long enough. Under operation, the stepper motors are energised which applies a holding torque. That is what stops the axes moving when you are cutting. So yes it is normal.
Regardshttps://emvioeng.com
FOR SALE: Boxford A3 HSRI 3D High Speed Router
By Bartell in forum Items For SaleReplies: 6Last Post: 18-06-2021, 09:03 PM -
Redsail laser engraver x axis problem
By sthdklen in forum Laser Machines & BuildingReplies: 4Last Post: 21-03-2015, 03:44 PM -
NEW MEMBER: Training & Buying CNC router/engraver
By etched-in in forum New Member IntroductionsReplies: 6Last Post: 01-02-2015, 07:15 PM -
High speed router for aluminium tooling 3d profiling.
By gavztheouch in forum Spindles & Drive MotorsReplies: 7Last Post: 07-02-2014, 02:30 PM -
eBay: 1500 x 1000 router any use ?
By EddyCurrent in forum Items On eBay UKReplies: 3Last Post: 24-12-2013, 12:18 PM
