    I wonder if supported rails generally run “unsmooth”?
    Guit no previous experince from them but i would have imagined them to run more smooth and quiet. Off course it’s hard to explain like this, they probably are perfectly ok but i think I’ve read somewhere about a guy that cleaned them and applied new, better grease in the bearings.
    The supported rails are TBR20´s from linearmotionbearings.
    Anyone who knows what im talking about? :)
    //JW
    Yes I know exactly what your talking about and have used many of Chai's rail/bearings.
    If your trying them by hand off the machine then it's normal to feel this way. To get a true feeling for them put on flat surface ie:Flat floor and stand on the bearing then move with your weight on and you'll feel they run smooth.
    If not smooth when on the machine then chances are the plastic cage may have been damaged when fitting the bearings to rails or one or more balls feel out when fitted.
    Thankyou!!
    hi , a bit off topic but can these rails be used on their side? Click image for larger version.
    Quote Originally Posted by outtastep View Post
    Yes
  1. "Hacking" and "Modding"
  2. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  3. Replies: 4
    Last Post: 28-09-2012, 12:06 PM
  4. "Racks" VS "ball screw"
  5. Replies: 1
    Last Post: 25-12-2010, 06:05 PM
