    Rufe0 he needs it concaved your code is convexed.
    There you go 4x4 saved as a STL let me know
    Also, by programming a ball-nose tool to trace an arc, it will not cut the same path, unless the tool radius is zero! This is due to the way the contact point on the tool moves - my quick diagram should make it obvious:
    Try it Old school and learn G-code from Master TP (terry parker).!!! https://www.machsupport.com/forum/in...?topic=24988.0
    RE: JAZZCNC
    It looks pretty concave to me, I guess if you had your machine set with the Z low at the top and high at the bottom then it would be, anyway it's a simple task to do file>replace the G2>G3 and vise versa.
    RE: Jonathan
    Yes I forgot to mention he would need a ball nose tool with radius less than 5 17/32.
    You could do it longitudinally with a normal endmill but you'd be massively wearing the tooth corners out and it would take practically a million passes to get smooth.
    The ideal way todo this would be with a fly cutter however you'd need a horizontal mill, unless you could fix the work piece vertically.
    Quote Originally Posted by Rufe0 View Post
    RE: Jonathan
    or equal to! But more seriously, that's not the point I was making - your code will be more accurate as the tool diameter tends to zero, so clearly you need to compensate the tool height as in my diagram.
    I'm not sure that the code Jazz has linked to does this either?
    RE: JAZZCNC
    Hey!! Think you'll have to explain that one to me.? Only way that code would cut concave is if machine was upside down . . . But like you say to get it concave is easy fix but still not correct because like Jon points out there's no tool height Comp.
    Think it does Jon because he's got tool dia in one of the params and does some maths with it but I haven't checked it so could be wrong.!! . . . Terry isn't a muppet so would have took the easy route I'm sure if not.?
    To cut the correct concave profile, you need to cut along a diameter which is the tool diameter subtracted from the diameter of the surface you wish to cut. Having looked more carefully, I can confirm that Terry has done this (the line #1000=[#1040-#1030]), so barring other errors, he is not a muppet, at least in this case.
    I plotted a graph to demonstrate. The blue line represents the desired surface, red line is the toolpath (so an arc of radius [r_surface-r_tool]), and the red circles represent the tool. You can see it touches nicely at a tangent.
    So, sorry Rufe0, but in Jazz's words, you apparently are a muppet!
    Ah ah you shit stirring little Geek I wasn't calling anyone a Muppet or having a go at Rufe0 so bugger off and twiddle some wires. .
  10. The Following User Says Thank You to JAZZCNC For This Useful Post:
  11. #10
    Ah I think I've figured out the confusion, in mach 3 it's convex but I was using quick and dirty toolpath simulator. Tried it in a couple other simulators I had when you questioned it and they where all concave. I think it's the G18 XZ axis designation, in Mach3 the CW/CCW circular interpolation is in respect to the back elevation whereas everything else it's the front.
  1. RFQ: Small aluminum milling/water cutting
    By Harry Hills in forum Projects, Jobs & Requests
    Last Post: 02-11-2014, 01:54 AM
  2. NEW MEMBER: where to buy aluminum extrusion
    By troyboy1 in forum New Member Introductions
    Last Post: 21-07-2014, 01:52 PM
  3. symmetrical hart shape in vectric v carve pro
    By cockneyrebel in forum Vectric
    Last Post: 24-02-2014, 02:55 PM
  4. Flexible Stainless Steel pipe that holds its shape?
    By Fivetide in forum Marketplace Discussion
    Last Post: 14-02-2013, 07:35 PM
  5. tool for aluminum on uk
    By edgas10 in forum Tool & Tooling Technology
    Last Post: 26-04-2011, 11:23 AM
