  1. #5
    Ok, thanks for all the information.
    Think will try the PCI card first, then see (er actually already ordered it with the machine so no choice now). Did wonder how an external motion controller can be 'better' than PP. If the mach3 is giving timing pulses via the parallel port, how can these be improved upon by an addon controller?
    If I do end up having to use an external motion controller, can the autolevel signal still be connected directly to the PP? From others, it seems making a reliable pcb is impossible without autolevelling.
    On edit:
    found this: http://lab.whitequark.org/notes/2014...dden-features/
    which has the PP pinouts - 15 is the probe input. It also has a hack to control spindle speed via software.
  1. DIY 3020 CNC I/O Board
    By Pointy in forum Electronic Project Building
    Last Post: 27-07-2015, 10:48 PM
  2. CNC 3020 Enclosure/Upgrade
    Last Post: 27-10-2014, 10:20 PM
  3. Cutting Aluminium With A Cheapo 3020 CNC
    By Pointy in forum Metalwork Discussion
    Last Post: 05-05-2014, 09:59 AM
  4. is a cnc 3020 right for the jobs i need doing
    By RsvRcarl in forum Milling Machines, Builds & Conversions
    Last Post: 28-03-2012, 01:34 AM
  5. Improving your CNC3040/3020
    By DanielF in forum Motor Drivers & Controllers
    Last Post: 22-11-2011, 01:48 PM
