02-12-2015 #101
Duplicate. Please delete.
02-12-2015 #102
02-12-2015 #103
Thanks Cropwell - That base only has a contact rating of 6A. This is a 10A relay.
They do exist, but i can't really be bothered to buy / wait. Is there any reason why I can't solder the connections and heatshrink?
I trust solder over screw terminals.Last edited by mturneruk; 02-12-2015 at 10:00 PM.
02-12-2015 #104
08-12-2015 #105
How's it coming on Martin? Any updates?
The Following User Says Thank You to njhussey For This Useful Post:
08-12-2015 #106
some real good information in this thread, one for the bookmarks I think.
As Im sure many others have, Ive often thought about messaging Lee to get him to set up one page. Off this page, have diffinitive links to all the threads for each subject. For example this would be a great candidate for control box wiring. I can think of other threads where people have eloquently explained other subjects.
I too will be adopting the circuit design Dean has so well explained on my mill. Thanks for all your patience on this one Dean. Keep up the good work and updates mrturneruk.... more pictures required!!
08-12-2015 #107
Hey guys....
Ended up redesigning my room to fit in my new machine.
Then I decided that I needed a new floor and that the walls needed painting, so I've been doing that. Workshop is looking great now!
All the electronics parts are now in and the decoration is nearly complete.
So hopefully get back on it in the next week or so.
Here is a picture of the stand I am going to build, for my machine to sit on showing control box and dust extractor under the table.
The machine has to be on wheels as it blocks a hatch door into my loft. I will need to be able to move the machine out the way for access.
I have got a sloping ceiling, so I had to work out how high i could make the stand.
Would like it a bit higher really, but this should be just about ok.
Will post lots of pics of my build as I get into it.
Martin
09-12-2015 #108
Guys..
Just a thought. Would you say it's a definite no-no to run the shielded VFD to spindle cable in the same drag chain as the rest of the shielded cables to steppers / sensors ?
It would be real ugly to have this cable floating around or to have two drag chains.
Martin
09-12-2015 #109
In an ideal world you run power down one side and signals down the other. There are lots on this forum happily running everything together. If your power cables and signal cables are all shielded then it should be fine.
09-12-2015 #110
Yes it's fine and if it's water cooled Spindle just try to put the water pipes between signal and power cables. Provided you have correct grounds then you shoudln't have any troubles.
Edit: Doh didn't see neils post.! . . Same What he said. . .LolLast edited by JAZZCNC; 09-12-2015 at 10:47 AM.
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
1.5Kw Chinese Spindle help
By Hasanain in forum Generic Chinese SpindlesReplies: 3Last Post: 26-05-2016, 10:38 AM -
WANTED: 2.2 KW Chinese Spindle
By Chaz in forum Items WantedReplies: 2Last Post: 17-06-2013, 10:03 AM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
