Page 12 of 21 FirstFirst ... 21011121314 ... LastLast
  1. #111
    Just a small comment on the solder vs crimping or screwing.
    In high vibration environments such as in aircraft, drilling tools and military vehicles, it has been found that solder joints are more likely to fail. The solder wicks up into the cable and causes a hidden stress concentration and a slight heat affected zone in the copper. Also tin whiskers as discussed here: http://www.aviationtoday.com/av/comm...ers_76599.html
    Depending on your application, my recommendation would be to see if you can crimp a ferrule boot on to the cables and use screw terminals. Also to note, some screw terminals are not meant to take a soldered cable in them.
    https://emvioeng.com
  2. #112
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 18 Hours Ago Has a total post count of 807. Received thanks 101 times, giving thanks to others 176 times.
    A very interesting yet disturbing read, thanks for that
    Regards
    Mike
  3. #113
    If you buy solder from China, it is generally 63/37 Sn/Pb, which avoids the whiskering problem. Commercially you can't use it, but as an amateur you are not bound by recent regulations to industry. If you are not soldering all day and everyday the risk is low.
    Most spindle connector plugs have to have soldered joints and I would recommend that you use at leat a 50W iron with a large bit. Low wattage irons and small bits don't transfer heat quickly enough to stop the heat soak up the wire. The faster you can solder a joint (at the correct temperature) the better.
    To echo and amplify the remarks of Komatias, you will need to cut down the joint flexing as it is more likely to fail at the solder due to embrittlement of the wire. If you can fit a flex limiting sheath (several layers of heat shrink will help) then you increase the radius of curvature at the flexing point.
    Cheers,
    Rob
    https://www.gore.com/en_xx/products/cables/flat/highflex/flat_cable_hi_flex_apps_tech_background_document.h tml
  4. The Following User Says Thank You to cropwell For This Useful Post:
  5. #114
    This is what I love about this forum, so much information on so many different topics by the members :)
    Neil...
    Build log...here
  6. #115
    God forbid - If the worst should happen with my machine and for what ever reason the sensors didnt read the end stop position or user error, what do you think would give first. Steppers ? Can't see the frame breaking.
  7. #116
    Your trousers......;)
    Neil...
    Build log...here
  8. #117
    yeah I agree, your trousers would be needing some attention.
  9. #118
    Fingers.!!!. . .Then under wear.. .
  10. #119
    lol. Cheers Chaps. I assume you have never done it then...
  11. #120
    I've jogged the Z axis into the frame sides slowly and caused the drives to fault but never (yet...) full on crashed it. Slapped the "OH SHITTTTTT" button a few times after forgetting to re-zero and the machine's taken off in an unexpected direction....
    Neil...
    Build log...here
  2. 1.5Kw Chinese Spindle help
    By Hasanain in forum Generic Chinese Spindles
    Last Post: 26-05-2016, 10:38 AM
  3. WANTED: 2.2 KW Chinese Spindle
    By Chaz in forum Items Wanted
    Last Post: 17-06-2013, 10:03 AM
  4. Electronics upgrade for an existing machine.
    By Shinobiwan in forum Electronic Project Building
    Last Post: 18-03-2012, 04:01 PM
  5. WANTED: Spindle holder for 1.5kw Chinese spindle.
    By jcb121 in forum Items Wanted
    Last Post: 14-10-2011, 02:07 PM
