    I have just proved that it's related to load on the cutter.
    I tested cutting about 3mm passes of birch ply (now scrap) while Jogging. After only a few centimetres Mach3 would stop (As i mentioned before when i was surfacing my bed).
    It just did it about 10 times in both X and Y directions. Each time no error condition was present in Mach 3.
    All i needed to do was to go in the other direction and then it would work in the direction which had stopped working previously (With a bit of a jolt to start).
    I really don't think it was my keyboard. It'a a Steel series shit hot mechanical key thing.
    Having got it to do that consistently, as soon as i rose out of the material and did the same thing, it did not stop at all.
    This is consistent with my experiences so far.
    Could this mean the drivers are at at fault in some way. Something to do with all those dip switches possibly ?
    Overheating, protection kicking in or something?
    Maybe I should of gone for those Leadshines as you suggested.
    As usual. Thanks for your excellent replies Jazz. Is this your forum ?
    Martin
    Quote Originally Posted by mturneruk View Post
    No guarantees, but I saw something very similar when I first set up my 3D printer. What's the max current setting on your drives? Yes, decode those DIP switches! Could be that if these are set too low, you are just not generating enough torque to move the spindle under cutting load.
    I hope your right.
    I have current set to 3.8 as recommended by CNC 4 You.
    e.g.
    SW1. Off
    SW2. Off
    SW3. On
    SW4 is set to off. (e.g. Half current mode).
Name:	stepper cwd556.png
    Edit : I am running 10 Microsteps.
    Martin
  5. #4
    Don't know if this is related to your problem or not but from time to time in the past I've had e-stops when the cutting loads suddenly increased. If the cutter was clogging up (aluminium) and slowing or stopping the spindle it could trip the e-stop.
    I assumed this was increased electrical noise from the VFD as the amps shot up, and any long cables were like antennas which fed this into the BOB. In particular the long run to the Z seem most affected.
    Since upgrading to 24V on the e-stop & limit circuit (i.e. relay into the BOB with very short wires) I've not had an unintended e-stop due to sudden load increases.
    So when you do an air cut things are different to doing the real cut in terms of VFD load and this is another factor to consider in the diagnosis. Having said that if Mach3 is not e-stopping then it surely points to something in the UC300 or USB?
    Not sure if you were joking but this forum was set up by Lee Roberts [and we are all indebted to him for doing so]. Dean (JazzCNC) is a massive contributor so you could be mistaken for thinking that, but it is not his creation. On that subject I think Jonathan is still a moderator ?
  6. #5
    Just re-reading Jazz's post Number 132.
    The Amps should match or be close to the Motors rating as possible. Good drives will let you set exactly to match motors but If no exact match then set to next lowest. You'll just have lower than rated Torque but better than going higher and having more motor heating.
    Here is a link to the spec sheet for my motors.
    http://cnc4you.co.uk/resources/Stepp...1-03%204Nm.pdf
    It seems to suggest they are rated for 4 Amps (if I understand the spec correctly). Hence the 3.8Amp suggestion i guess.
    So where do i go from here i suppose is the question.
  7. #6
    Hear you Jazz.
    So you don't think it's load related.
    In that case is it possible that the VFD is generating a lot more noise when it's cutting rather than just running ?
    Is the next test to take the VFD out of my enclosure?
    Nightmare...
  8. #7
    Hear you Jazz.
    Yes it's possible but whether or not that is the problem I'm not so sure.! The easy way to check is to remove the VFD from the Control box.
    The VFD cables running thru the machine shouldn't be a problem provided you have a little separation from signal cables.
    Like I say this won't be load related because I've pushed cutter thru MDF without spindle running and motors not stalled before material is ripped from bed so with the small DOC and low Feed rate you have been using then it won't be load. Even with a very tired cutter it wouldn't cause this problem.!. . . Again thou easy checked just throw a new cutter in it.!!
    The amps are fine at 3.8A. 2000(10x) micro steps are fine so you have no issues there.
    It's not the drives protecting them selfs, they would just fault and blink at you showing what cause the fault.
    Can you make it do it and video it. This may highlight some things. Also show the Electrics and wiring around machine.
  9. #8
    Thanks Jazz. First job in the morning.
  10. #9
    OK.
    So here is a video of the problem.
    https://www.youtube.com/watch?v=SeALZMIaJ70
    If you want me to video inside the box i will.
    I was racking my brains this morning and i remember something similar happening on my previous machine when jogging.
    Could this possibly point to the fact that my problems are possibly connected to the PC / mach3 driver / plugin?
    Martin
  11. #10
    NO the Forum belongs to and is kindly run by LEE Roberts. . . . . . . I just come on and cause trouble.!
    Your problem is NOT Load related. No cutting can or should stop Mach3 from working. The motors can stall or miss steps but will never stop Mach working or break connection to Controller.
  2. 1.5Kw Chinese Spindle help
    By Hasanain in forum Generic Chinese Spindles
    Last Post: 26-05-2016, 10:38 AM
  3. WANTED: 2.2 KW Chinese Spindle
    By Chaz in forum Items Wanted
    Last Post: 17-06-2013, 10:03 AM
  4. Electronics upgrade for an existing machine.
    By Shinobiwan in forum Electronic Project Building
    Last Post: 18-03-2012, 04:01 PM
  5. WANTED: Spindle holder for 1.5kw Chinese spindle.
    By jcb121 in forum Items Wanted
    Last Post: 14-10-2011, 02:07 PM
