Hey Chaps..
Byuilding my second DIY router. This one is a fairly serious bit of kit compared to my first openbuilds OX.
I would be very grateful for a bit of advice on purchasing the electronics for my new machine, before I take the plunge.
I have already purchased a Huanyang VFD and 2.2kw spindle from Solar Jean. Fingers crossed it works.
Q1. On my previous machine I used a UC100 motion controller attached to a HG08 breakout board from CNC4YOU in the UK.
Do you think there is a better set-up than this within a sensible budget?
If I went down the ethernet route - maybe ESS? (which I have heard is more reliable than USB) can you connect the machine to your network, or directly to the pc only?.
There is only 1 ethernet connection on my PC and i need it for the internet.
Q2. I am planning to mount all the electronics including the VFD in a single enclosure. Do you think i will have noise issues ?
I will be using shielded cables all round.
Q3. It would be nice to have one single power input into this enclosure to power the 36v transformer for the steppers and the VFD. Any issues ? RFI Filter ?
Q4. I am confused about connecting Mach3 to the VFD. Is it even worth it ?. Are there any benefits ?
I see that a UC300 has some kind of PWM spindle control option on it, but got no idea how to connect this to the VFD and i can't find any wiring diagrams on the net.
Q5. I have read that it is possible to break the Huanyang VFD / Spindle if i do not set-up the VFD correctly to start with.
Can anyone confirm that this is true, and point me in the correct direction to get the settings right before I start ?
Thanks for any help on all of this.
Martin
