Page 9 of 21 FirstFirst ... 789101119 ... LastLast
  1. #81
    They will sense Aluminium but you have to get very very close and they are erratic so NO is the answer. Sense to a bolt head or Metal plate etc.
    If you run your target bolt head axially on to the sensor, one day you will jog onto it and crush the coil in the head. Put your sensor at right angles to the motion of the axis, so the bolt passes by the sensor. My MD machine was designed with axially mounted sensors. Jeesh !
    Rob
  2. The Following User Says Thank You to cropwell For This Useful Post:
  3. #82
    Rob common sense to me and can't believe MD or anyone would position any switch not to mention Prox switches so they could be crashed into.!
    Another reason is the sensing repeatabilty is actually better when sliding over rather than approaching head on. Most Quality Prox switches data sheets will give specs on both types of approach.
  4. #83
    Lives in Plymouth, United Kingdom. Last Activity: 6 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Common sense because you've researched and tested the answer! I would have thought (probably like a lot of people) that end-on would give better results although I am now quite convinced as a result of your testing demo a while back. I did worry about over-run though, and it's good to know that there's a simple answer.
  5. #84
    OK Great. Thanks Jazz.
    So hopefully that's the plan sorted now. Reckon I might get stuck along the way, but i will give it a go.
    So am i right in saying I need NC ones. So that when it detects something it opens and breaks the circuit ?
    I will have to ensure that the aluminium frame of the router won't cause false triggers then on the prox switches.
    Does NPN or PNP matter for my purposes ?
    Do these look like they will do the job?
    http://www.ebay.co.uk/itm/1-5Pcs-Ind...U0u32s_xiK0nkw
    Thanks again for all your help. Couldn't of done without it.
    Martin
  6. #85
    Quote Originally Posted by mturneruk View Post
    Martin
    It depends on the BOB you are using. the one's you have linked to are about £4 each I have linked to some for £1.41 http://www.ebay.co.uk/itm/1417817891...c=1&rmvSB=true
    these are NO so would need to be wired in parallel if you only want to use one input on the BOB for the three switches.
    If your BOB has hardwired pullups to 5 V you would need NPN type. otherwise either will do.
  7. #86
    NPN or PNP depends on your control. Nearly all have either +5 or +24V inputs,
    for those you need NPN. I have never seen any control unit who works with ground signals. But it must exist, because so many PNP switches are offered.
  8. #87
    Sorry to be dumb guys but im getting lost within the techno on your answers to my question, I am no electronics engineer!
    I found this wiring diagram for my KK01 specifically for prox sensors..
    There are also some words underneath which say..
    "We would normally recommend using one input for all limit switches and wirethem through normally closed contacts in series when using mechanical limitswitches and parallel for normally open or open collector proximity switches etc. "
    Can I just copy this wiring diagram for the sensors and put my 24v in where it says 6-36v?
    Any problems with this ? They suggest these prox switches : LJ12A3-4
    Martin
  9. #88
    Martin The ones I linked to will be fine and yes the drawing is OK If you are going to just use one input.
    But do the Estop circuit as you have been advised by Jazz earlier
  10. The Following User Says Thank You to Clive S For This Useful Post:
  11. #89
    Thanks. Absolutely!
  12. #90
    Like Clive says yes you can wire just like that.
    Also you use the E-stop portion the same but instead of running thru the E-stop button like they show run it thru the Relay Contacts of the E-stop system I did for you. Then power the Relay coils like I show using the E-stop button.
    That's because they want you to buy there switches. Prox switch is a prox switch doesn't matter who you buy it from or what make provided you use the right type to suit your needs.
    Martin
  2. 1.5Kw Chinese Spindle help
    By Hasanain in forum Generic Chinese Spindles
    Last Post: 26-05-2016, 10:38 AM
  3. WANTED: 2.2 KW Chinese Spindle
    By Chaz in forum Items Wanted
    Last Post: 17-06-2013, 10:03 AM
  4. Electronics upgrade for an existing machine.
    By Shinobiwan in forum Electronic Project Building
    Last Post: 18-03-2012, 04:01 PM
  5. WANTED: Spindle holder for 1.5kw Chinese spindle.
    By jcb121 in forum Items Wanted
    Last Post: 14-10-2011, 02:07 PM
