13-01-2016 #171
Thanks Jazz. First job in the morning.
14-01-2016 #172
OK.
So here is a video of the problem.
https://www.youtube.com/watch?v=SeALZMIaJ70
If you want me to video inside the box i will.
I was racking my brains this morning and i remember something similar happening on my previous machine when jogging.
Could this possibly point to the fact that my problems are possibly connected to the PC / mach3 driver / plugin?
Martin
14-01-2016 #173
Common denominator being the Keyboard.? . . . Did you try changing the keyboard as I suggested.? I've had many daft happenings like this over the years and it's been keyboard related.
I think you have 2 issues really. The losing connection I'm 99% sure is noise affecting the USB.
The Jogging I'm betting is keyboard related.
14-01-2016 #174
1. Reinstalled Mach 3 from scratch and re-entered all my settings. Same problem.
2. Just tried a different keyboard. Same problem.
3. Purchased UCCNC as an alternative to mach 3. That's the next test.
After that i suppose i have to assume it's noise and i will have to try taking the VFD out of the box.
14-01-2016 #175
UCCNC seems to be fine.
I cannot get it to crash or stop and I have just run several jobs successfully. I even ventured up to 2500 mm / sec feed rate towards the end and no problems.
Weird why that should solve it.
I have to say I like UCCNC a lot. It's cleaner and has a much better interface, and is much simpler which is what i have been after. So i will keep an eye on it for now until i have some confidence it's not going to go mental on me.
Cheers Chaps. Thanks for all your help.Last edited by mturneruk; 14-01-2016 at 05:59 PM.
14-01-2016 #176
My money is on the PC being the problem and I would swap that first, think if you had a noise issue the symptoms would be more constant. Watching the video and what you can do to get it working again suggests to me it's some sort of buffering problem, when you send a keystroke it could be clearing that, the minute you release, the other tools start sending signals and off she go's again.
What's strange is how it doesn't do it when cutting air...hummm
What hardware is existing from the previous machine.
.MeLee
14-01-2016 #177
14-01-2016 #178
The Following User Says Thank You to Lee Roberts For This Useful Post:
20-01-2016 #179
Ok. So after some more testing with the UC CNC software i am still getting the odd reset during a cut. No crazy lost steps though which is good.
So I have decided I am going to bite the bullet and redesign a new bigger box for all the electronics, as I am sure the packed in proximity of everything is part of my problem.
At least now I can use the machine as is to make it.
I am planning to make the box out of 18mm birch ply as i have it.
I would ideally like to get the vfd in the same box, but with a significant internal shield to separate it from the sensitive stuff.
Also I am wondering whether my dust extractor which sits under my bench in fairly close proximity to the box could be causing me a noise problem as well.
Can anyone tell me what materials block noise? Or would you fail safe and just separate the VFD completely.
Would it also be sensible to separate and shield the mains stuff from the low voltage stuff ?
I assume wood doesn't do anything.Last edited by mturneruk; 20-01-2016 at 11:14 AM.
20-01-2016 #180
M,
you are in Bristol right? Would you like me to come and have a look? 4 eyes better that 2.https://emvioeng.com
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
1.5Kw Chinese Spindle help
By Hasanain in forum Generic Chinese SpindlesReplies: 3Last Post: 26-05-2016, 10:38 AM -
WANTED: 2.2 KW Chinese Spindle
By Chaz in forum Items WantedReplies: 2Last Post: 17-06-2013, 10:03 AM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
