  1. #30
    Hey George.
    I decided to run a little bit more to see how often the problem occurred and see if I could spot a pattern. E.g. Did it always happen under load ?
    Well i have just run nearly 1/2 a million lines of GCode cutting a complex 3d model with 6mm and 3mm ball noses (in four batches) and I have not had one reset.
    I was getting really adventurous on the feed towards the end of the job. Ended up running at over 4000 mm / Minute.
    I will keep an eye on it for now and record when and if I get resets.
    I will definitely run a separate bare earth wire to the machine through the dust collection PVC pipe to ensure static is not an issue and earth this to the machine as well. Then I can disconnect the shielding of the VFD cable at the machine end as you suggested.
    One thing you said has definitely helped me and that is to make a note of my machines co-ordinates at my job Zero point.
    This allows me to check that my machine is absolutely in the right place for each session of machining i do, and return to my zero point if I should get a reset. Very good idea.
    Will keep you posted.
    Thanks again.
    Martin
  2. 1.5Kw Chinese Spindle help
    By Hasanain in forum Generic Chinese Spindles
    Last Post: 26-05-2016, 10:38 AM
  3. WANTED: 2.2 KW Chinese Spindle
    By Chaz in forum Items Wanted
    Last Post: 17-06-2013, 10:03 AM
  4. Electronics upgrade for an existing machine.
    By Shinobiwan in forum Electronic Project Building
    Last Post: 18-03-2012, 04:01 PM
  5. WANTED: Spindle holder for 1.5kw Chinese spindle.
    By jcb121 in forum Items Wanted
    Last Post: 14-10-2011, 02:07 PM
