  1. #2
    photos are a bit all over the shop , this is the most recent version- Click image for larger version.
Name:	bracket on gantry.jpg
ID:	16606most of the steel, like deck and y rails and gantry sides was to be 100x50mm steel maybe 2 or 3mm thick, with the gantry maybe 150x50. The X carriage is envisaged as a aluminium plate perhaps 10mm thick with lots of bearings either side, z bit aluminium plate made into a bit of a box. was hoping to get 250mm travel on Z. Gantry is 300mm above bed/ deck/base. Might be pushing it a bit with Z.
    With the base i was thinking of 5mm steel plate. there is also steel plate in corners of and holding ball screw ends/ motors.
    im a bit concerned with having this type of supported rail as i have read some bad things about the here, also probably not the best having them on their side as per my x axis ?
    cheers ben
  1. BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
    By grain_r in forum DIY Router Build Logs
    Last Post: 27-01-2023, 06:47 PM
  2. Using stainless steel tube for linear bearings
    By shoeswith in forum Gantry/Router Machines & Building
    Last Post: 31-07-2017, 03:19 PM
  3. BUILD LOG: First steel diy CNC router build
  4. I need to build a tube profiling machine
    By Paulgy80 in forum Gantry/Router Machines & Building
    Last Post: 13-04-2014, 12:58 PM
  5. Replies: 41
    Last Post: 08-02-2014, 11:37 PM
