25-11-2015 #12
all good questions , ill attempt to bluff my way through
......gantry - steel tube 3mm, drill and tap thread , or weld threaded rod to tube ?
x carriage - aluminium plate and angle bolted togeather, rails bolted through
z axis - maybe thicker plate 20mm ?
i worried about this, maybe only weld below y rails and shim them out to put y rails on then above this bolt together
so better just to have stiffer plate ? and forget sides
3mm , lots of jigs and clamping
very good suggestion, my current machine has no issues like this as it is so sloppy no resonance builds up !
Can't comment in the plasma thing as no experience with them, I'm sure a dual machine could be built but as with anything that doesn't do just one thing, there will be compromises.
thanks for persevering with my somewhat undeveloped project
cheers
ben
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
Using stainless steel tube for linear bearings
By shoeswith in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 31-07-2017, 03:19 PM -
I need to build a tube profiling machine
By Paulgy80 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 13-04-2014, 12:58 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM
