  1. #16
    Quote Originally Posted by outtastep View Post
    if i reduce z travel by 100 mm and bring material up with a raised bed do you think the machine is more solid or still compromised by gantry height?
    Yes provided you keep the Distance or Z axis extension short then you won't have a problem. But this is still a slight compromise on overall machine stiffness because you still need to create that height in the first place which weakens the machine to some degree compared to short stubby design but it is the lesser of two evils I suppose.!
    For machines like what you want then having a moving bed is best option because it gives the best of both worlds but keeps the machine stiff compared to just packing the Bed up.
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
    By grain_r in forum DIY Router Build Logs
    Last Post: 27-01-2023, 06:47 PM
  2. Using stainless steel tube for linear bearings
    By shoeswith in forum Gantry/Router Machines & Building
    Last Post: 31-07-2017, 03:19 PM
  3. BUILD LOG: First steel diy CNC router build
  4. I need to build a tube profiling machine
    By Paulgy80 in forum Gantry/Router Machines & Building
    Last Post: 13-04-2014, 12:58 PM
  5. Replies: 41
    Last Post: 08-02-2014, 11:37 PM
